ZHA send attribute instead of command
im quite new to HomeAssistant, today i added my Moes TRVs to the system. Sadly i cant figure out how to close the valve when my window sensor gets opened.
So far i was able to create the following automation, sadly this isn’t working because it sends a command to the valve, not an attribute. Setting the attribute to 0, 1 or 2 changes the valve to immediately close, open or go back to normal behaviour:
alias: Close Valve When Window Opens
description: ""
  - type: opened
    platform: device
    device_id: <dev_id>
    entity_id: <ent_id>
    domain: binary_sensor
condition: []
  - service: zha.issue_zigbee_cluster_command
      ieee: <ieee_addr>
      endpoint_id: 1
      command_type: client
      cluster_type: in
      cluster_id: 513
      command: 1
      params: {"valve_force_state": "1"}
Thank you
