I’ve some Zigbee devices from Aqara/Ikea/Philips Hue as well as some Osram Plugs. Those Osram Plugs are working ok (except for not seeing button presses on the plug itself). But I can switch them in Home Assistant as expecting.
I’ve a problem with my Aqara Motion Sensors that are not working reliable when having one of those Osram Plugs as router. Is there a way in ZHA to strictly set a powered Zigbee device as End Device only? So it will not try to act as a router to some other end device?
This is protocol level thing in Zigbee, The devices pick thie rown routing - there is no way to micromanage routing from the user perspective. As Francis said - it is simply not possible.
Aquara devices are known to not play nice with other Zigbee standard routing devices. THere’s many articles here , on SmartThings’ Vera’s Hubitat and other’s community sites lsting the many issues Aquara devices have with routing and the common solution comes down to either 1) don’t use them (my personal solution - I simply won’t buy them, cheap isn’t worth the massive pain in the butt of dealing with the rouging issues and devices always dropping off) 2) pick devices from a very small list that are known to play nice. (I do not have the list - I don’t use Aquaras on purpose.)
