I have just set up a skyconnect dongle and configured ZHA on my home assistant. I am able to find all the devices I need but I am having problems with my RWL021 Hue Dimmer switches. I want to bind them to specific groups, and having googled a fair bit I have gathered that by default the dimmer is bound to the controller. I cannot for the life of me figure out how to unbind the dimmer from the controller so I can bind lights to them.
Same problem here.
How do we file this as a bug. I can see this has been raised and possibly fixed before but it is not possible with skyconnect.
Go to the device config page → three dots → Manage Zigbee device. Then, select the “Bindings” tab and in the first drop down menu, select your Zigbee coordinator, then press unbind. Immediately after that, press some buttons on your remote, so it wakes up.
Pictures:
Yup I know how to, issue is it doesnt work :). Hence my comment about it being a bug.
is there a solution?
Bump lol, trying to migrate away from hue and would like to bind remote instead of having an automation… same issue as there is no response after binding
Same issue here.
Moving from older Home Assistant on own server with Conbee & DeConz where it works perfectly to Home Assistant Green with skyconnect.
Now i cant bind my switch to any bulbs or groups anymore.
Is this an issue with just this switch ?
Never Home-assistant ?
skyconnect ?
