ZHA Stopped working all of a sudden, not sure why
Home Assistant Version
Core 2025.3.4
Supervisor 2025.03.3
Operating System 15.0
Frontend 20250306.0
SLZB-06 by SMLIGHT
Firmware: core: v2.7.1 / zigbee: 20240710
I’ve removed them both from Home Assistant, Re-added SZLB which was fine I can connect to it via UI but when I add ZHA It’s found SLZB-06 but “Fails to connect”
This is the log from Home Assistant Core
2025-03-31 10:57:44.218 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Ledvance(url='https://api.update.ledvance.com/v1/zigbee/firmwares', manufacturer_ids=(4489, 4364))
2025-03-31 10:57:44.218 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Sonoff(url=None, manufacturer_ids=(4742,))
2025-03-31 10:57:44.219 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: Inovelli(url=None, manufacturer_ids=(4655,))
2025-03-31 10:57:44.219 DEBUG (MainThread) [zigpy.ota] Registering new OTA provider: ThirdReality(url=None, manufacturer_ids=(4659, 4877, 5127))
2025-03-31 10:57:44.234 DEBUG (MainThread) [zigpy.appdb] Current database version is v13 (table version v13)
2025-03-31 10:57:44.236 DEBUG (MainThread) [zigpy.appdb] Loading application state
2025-03-31 10:57:44.251 DEBUG (MainThread) [zigpy.appdb] [0x0000:1:0x0000] Attribute id: 5 value: Coordinator
2025-03-31 10:57:44.251 DEBUG (MainThread) [zigpy.appdb] [0x0000:1:0x0000] Attribute id: 4 value: Texas Instruments
2025-03-31 10:57:44.251 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0000] Attribute id: 4 value: Philips
2025-03-31 10:57:44.251 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0000] Attribute id: 5 value: LTA001
2025-03-31 10:57:44.251 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0000] Attribute id: 4 value: Computime
2025-03-31 10:57:44.252 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0000] Attribute id: 5 value: SP600
2025-03-31 10:57:44.252 DEBUG (MainThread) [zigpy.appdb] [0x7667:1:0x0000] Attribute id: 4 value: LUMI
2025-03-31 10:57:44.252 DEBUG (MainThread) [zigpy.appdb] [0x7667:1:0x0000] Attribute id: 5 value: lumi.sensor_magnet.aq2
2025-03-31 10:57:44.252 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0000] Attribute id: 4 value: Computime
2025-03-31 10:57:44.252 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0000] Attribute id: 5 value: SP600
2025-03-31 10:57:44.254 DEBUG (MainThread) [zigpy.quirks.registry] Checking quirks for Texas Instruments Coordinator (00:12:4b:00:2f:8e:4d:bf)
2025-03-31 10:57:44.254 DEBUG (MainThread) [zigpy.quirks.registry] Checking quirks for Philips LTA001 (00:17:88:01:08:aa:07:ae)
2025-03-31 10:57:44.254 DEBUG (MainThread) [zigpy.quirks.registry] Checking quirks for Computime SP600 (00:1e:5e:09:02:13:2e:38)
2025-03-31 10:57:44.255 DEBUG (MainThread) [zigpy.quirks.registry] Checking quirks for LUMI lumi.sensor_magnet.aq2 (00:15:8d:00:06:93:b1:da)
2025-03-31 10:57:44.255 DEBUG (MainThread) [zigpy.quirks.registry] Checking quirks for Computime SP600 (00:1e:5e:09:02:16:18:5a)
2025-03-31 10:57:44.264 DEBUG (MainThread) [zigpy.appdb] [0x0000:1:0x0000] Attribute id: 5 value: Coordinator
2025-03-31 10:57:44.264 DEBUG (MainThread) [zigpy.appdb] [0x0000:1:0x0000] Attribute id: 4 value: Texas Instruments
2025-03-31 10:57:44.265 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0000] Attribute id: 4 value: Philips
2025-03-31 10:57:44.265 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0000] Attribute id: 5 value: LTA001
2025-03-31 10:57:44.265 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0006] Attribute id: 16387 value: 1
2025-03-31 10:57:44.265 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0006] Attribute id: 0 value: 1
2025-03-31 10:57:44.265 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0008] Attribute id: 16384 value: 254
2025-03-31 10:57:44.265 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0008] Attribute id: 0 value: 254
2025-03-31 10:57:44.265 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 16395 value: 153
2025-03-31 10:57:44.265 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 16396 value: 454
2025-03-31 10:57:44.266 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 16394 value: 16
2025-03-31 10:57:44.266 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 16400 value: 366
2025-03-31 10:57:44.266 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 15 value: 0
2025-03-31 10:57:44.266 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 8 value: 2
2025-03-31 10:57:44.266 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 3 value: 29972
2025-03-31 10:57:44.266 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 4 value: 26871
2025-03-31 10:57:44.266 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0300] Attribute id: 7 value: 366
2025-03-31 10:57:44.266 DEBUG (MainThread) [zigpy.appdb] [0xeb82:11:0x0019] Attribute id: 2 value: 16780544
2025-03-31 10:57:44.267 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0000] Attribute id: 4 value: Computime
2025-03-31 10:57:44.267 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0000] Attribute id: 5 value: SP600
2025-03-31 10:57:44.267 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0019] Attribute id: 2 value: 610592
2025-03-31 10:57:44.267 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0006] Attribute id: 0 value: 1
2025-03-31 10:57:44.267 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 772 value: 0
2025-03-31 10:57:44.267 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 770 value: 10000
2025-03-31 10:57:44.268 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 774 value: 0
2025-03-31 10:57:44.268 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 769 value: 1
2025-03-31 10:57:44.268 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 771 value: 0
2025-03-31 10:57:44.268 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 768 value: 0
2025-03-31 10:57:44.268 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 1024 value: 1
2025-03-31 10:57:44.268 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 0 value: 11955118
2025-03-31 10:57:44.268 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 1 value: 0
2025-03-31 10:57:44.268 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0702] Attribute id: 512 value: 0
2025-03-31 10:57:44.269 DEBUG (MainThread) [zigpy.appdb] [0x32c3:9:0x0402] Attribute id: 0 value: 2150.0
2025-03-31 10:57:44.269 DEBUG (MainThread) [zigpy.appdb] [0x7667:1:0x0000] Attribute id: 4 value: LUMI
2025-03-31 10:57:44.269 DEBUG (MainThread) [zigpy.appdb] [0x7667:1:0x0000] Attribute id: 5 value: lumi.sensor_magnet.aq2
2025-03-31 10:57:44.269 DEBUG (MainThread) [zigpy.appdb] [0x7667:1:0x0000] Attribute id: 65281 value: b'\x01!\x85\x0c\x03(\x19\x04!\xa8\x13\x05!B\x00\x06$\x01\x00\x00\x00\x00\n!\x00\x00d\x10\x00'
2025-03-31 10:57:44.269 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0000] Attribute id: 4 value: Computime
2025-03-31 10:57:44.269 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0000] Attribute id: 5 value: SP600
2025-03-31 10:57:44.270 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 1024 value: 0
2025-03-31 10:57:44.270 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0019] Attribute id: 2 value: 33640736
2025-03-31 10:57:44.271 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0006] Attribute id: 0 value: 0
2025-03-31 10:57:44.271 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0402] Attribute id: 0 value: 2050.0
2025-03-31 10:57:44.271 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 772 value: 0
2025-03-31 10:57:44.271 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 770 value: 10000
2025-03-31 10:57:44.271 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 774 value: 0
2025-03-31 10:57:44.272 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 769 value: 1
2025-03-31 10:57:44.273 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 771 value: 0
2025-03-31 10:57:44.273 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 768 value: 0
2025-03-31 10:57:44.273 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 0 value: 227127
2025-03-31 10:57:44.273 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 1 value: 0
2025-03-31 10:57:44.273 DEBUG (MainThread) [zigpy.appdb] [0x8f69:9:0x0702] Attribute id: 512 value: 0
2025-03-31 10:57:44.328 DEBUG (MainThread) [zigpy.backups] Adding a new backup NetworkBackup(version=1, backup_time=datetime.datetime(2025, 1, 27, 12, 1, 57, 40385, tzinfo=datetime.timezone.utc), network_info=NetworkInfo(extended_pan_id=b1:6f:d9:19:ce:39:b1:7c, pan_id=0x41FC, nwk_update_id=0, nwk_manager_id=0x0000, channel=25, channel_mask=<Channels.CHANNEL_25: 33554432>, security_level=5, network_key=Key(key=6b:b2:c3:56:f8:1d:51:92:84:a0:75:e2:67:6d:8d:09, tx_counter=1250, rx_counter=0, seq=0, partner_ieee=00:12:4b:00:2f:8e:4d:bf), tc_link_key=Key(key=5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, tx_counter=0, rx_counter=0, seq=0, partner_ieee=00:12:4b:00:2f:8e:4d:bf), key_table=[], children=[], nwk_addresses={}, stack_specific={'zstack': {'tclk_seed': 'd59210f2f40e0cc8a7dfa7c1c4af1188'}}, metadata={'zstack': {'TransportRev': 2, 'ProductId': 1, 'MajorRel': 2, 'MinorRel': 7, 'MaintRel': 1, 'CodeRevision': 20240710, 'BootloaderBuildType': 0, 'BootloaderRevision': None}}, source='[email protected]'), node_info=NodeInfo(nwk=0x0000, ieee=00:12:4b:00:2f:8e:4d:bf, logical_type=<LogicalType.Coordinator: 0>, model='CC2652', manufacturer='Texas Instruments', version='Z-Stack 20240710'))
2025-03-31 10:57:44.328 DEBUG (MainThread) [zigpy.backups] Adding a new backup NetworkBackup(version=1, backup_time=datetime.datetime(2025, 3, 29, 5, 20, 14, 402470, tzinfo=datetime.timezone.utc), network_info=NetworkInfo(extended_pan_id=f7:6a:43:f7:47:3e:5d:a2, pan_id=0x6304, nwk_update_id=0, nwk_manager_id=0x0000, channel=15, channel_mask=<Channels.CHANNEL_15: 32768>, security_level=5, network_key=Key(key=35:ff:39:d9:45:00:65:0d:31:df:14:00:7e:bf:f9:d9, tx_counter=4370221, rx_counter=0, seq=0, partner_ieee=00:12:4b:00:2f:8e:4d:bf), tc_link_key=Key(key=5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, tx_counter=0, rx_counter=0, seq=0, partner_ieee=00:12:4b:00:2f:8e:4d:bf), key_table=[Key(key=e9:1d:51:cb:28:b4:89:cd:af:8a:2c:52:99:b6:2c:70, tx_counter=0, rx_counter=0, seq=0, partner_ieee=00:15:8d:00:06:93:b1:da)], children=[00:15:8d:00:06:93:b1:da], nwk_addresses={00:15:8d:00:06:93:b1:da: 0x7667}, stack_specific={'zstack': {'tclk_seed': 'cd753bbf54993b397033acc2cd28399c'}}, metadata={'zstack': {'TransportRev': 2, 'ProductId': 1, 'MajorRel': 2, 'MinorRel': 7, 'MaintRel': 1, 'CodeRevision': 20240710, 'BootloaderBuildType': 0, 'BootloaderRevision': None}}, source='[email protected]'), node_info=NodeInfo(nwk=0x0000, ieee=00:12:4b:00:2f:8e:4d:bf, logical_type=<LogicalType.Coordinator: 0>, model='CC2652', manufacturer='Texas Instruments', version='Z-Stack 20240710'))
2025-03-31 10:57:44.329 DEBUG (MainThread) [zigpy.serial] Opening a serial connection to 'socket://192.168.1.142:6638' (baudrate=115200, xonxoff=False, rtscts=False)
2025-03-31 10:57:44.332 DEBUG (MainThread) [zigpy.serial] Connection made: <_SelectorSocketTransport fd=81 read=idle write=<idle, bufsize=0>>
2025-03-31 10:57:54.334 DEBUG (MainThread) [zigpy.serial] Waiting for serial port to close
2025-03-31 10:57:54.334 DEBUG (MainThread) [zigpy.serial] Connection lost: None
2025-03-31 10:57:55.344 ERROR (MainThread) [aiohttp.server] Error handling request from 192.168.1.132
If I’m missing anything please let me know
Did you fix this? I have the same problem now, and it also happened all of a sudden for me. It was working fine yesterday, and I haven’t made any changes that could have caused this.
I finally fixed it by downgrading the Zigbee firmware to 20240315.
