ZHA - STYRBAR - Remote blueprint with multipress support
Hi there !
There is a blueprint that allows you to bind actions to your Styrbar 4 buttons Ikea remote, with multi-press support.
It allows you to bind different commands based on the number of presses within a certain time frame. For example you could go as far as 5 presses per button to trigger something.
Note that the up and down buttons are a bit stiff for some reason (or maybe it’s just my remote) so they don’t send updates as fast as the right/left buttons, which means that if you intend to get quintuple press working on the down button for example you should be a bit more generous with the timeout.
There is the gist to it: Blueprint to automate your Styrbar remote with ZHA · GitHub
It still allows you to use a separate automation running on restart if you want to do something like dimming control or something like this.
Let me know if that works well for you!
Hello Thomas,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
Note: if the original is in the forums here, only 1 code block can be in the top post ot the MY link tool will not work.
