ZHA Trådfri LED E14 470lm 5.2W
Has anyone else tried this bulb?
It looks like this
I tried connecting it via my ConBee 2 yesterday. It paired up after I performed a reset, then the logs showed a firmware update, in which I witnessed this:
Source: /usr/local/lib/python3.8/site-packages/zigpy/ota/image.py:241
First occurred: 1:27:56 AM (2 occurrences)
Last logged: 2:17:27 AM
Fixing IKEA OTA image with trailing data (1136 bytes)
but before and after the update, whatever I set the bulb to, other than ON 100% (e.g. dim, temperature), after about 20-50 seconds, the bulb just resets to ON 100% brightness.
Nothing appeared in the debug logs when the bulb reset, so I figured it was a bad bulb.
Has anyone else witnessed this behaviour before?
