ZHA - TS004F Rotary Knob with dual-mode support
Are you using custom quirk I have prepared?
I had the same results with my _TZ3000_gwkzibhs, it can’t find the device. I imported it and tried to set it up but no device was available. Sorry, I don’t understand how the custom quirks file works. If i copy and replace the manufacturer with _TZ3000_gwkzibhs then the short press seems to work but nothing else. not even sure how the dimmer part works or has to be set up. any help would be appreciated.
@erik-fiske your _TZ3000_4fjiwweb is already part of the TuyaSmartRemote004FROK in zhaquirks/tuya/ts004f.py. Same applies to @peterswan
Please check my custom quirk. It uses COMMAND_STEP_COLOR_TEMP that is not available in the TuyaSmartRemote004FROK.
Please copy quirk: HomeAssistant/zha_custom_quirks/ts004f_402vrq2i.py at b990e3a63e38a5b718fff2aa17be8a381d6de724 · jrfigura/HomeAssistant · GitHub
and change the models_info to include yours. The quirk evolved from TuyaSmartRemote004FROK and the description in the blueprint might no longer be correct. If your devices are rotary dimmers it might be good to move them to the new class
