Control a Media Player (like Music Assistant) with a generic Tuya Smart Scene Button (Knob) via ZHA.
I adapted this from existing lighting blueprints because media players lack a native brightness_step_pct equivalent. This blueprint includes custom Jinja templates to dynamically calculate volume stepping on the fly, plus it removes strict manufacturer/model filters so it works with almost all Tuya-based rotating scene buttons!
Credits
This blueprint was inspired by and adapted from the ZHA - Generic Tuya Smart Knob (TS004F) blueprint. Huge thanks to the original creators for laying the foundation!
Requirements
- Integration: ZHA (Zigbee Home Automation)
- Device: Tuya Smart Scene Button / Knob (Common models: TS004F, _TZ3000_402vrq2i, _TZ3000_qszcw1nx, MOES Smart Knob, etc.)
- Target: Any
media_playerentity (Works flawlessly with Music Assistant)
IMPORTANT: THIS DEVICE HAS TWO MODES
Switch between modes by rapidly tapping the physical button 3 times.
1. Normal Mode (Built-in Media Control)
- Single Press: Play/Pause the selected media player.
- Rotate Left/Right: Smoothly adjust the volume based on your chosen step percentage.
Note: If the device does nothing when you first set it up, tap it 3 times to wake up Normal Mode!
2. Remote Mode (Custom Actions)
In this mode, default volume and play/pause logic is ignored. Instead, it executes the custom actions you assign in the UI for:
- Short Press
- Double Press
- Long Press
- Rotate Right
- Rotate Left
The Blueprint Code
blueprint:
name: ZHA - Tuya Smart Scene Button (Knob) for Media Player - v1
description: >
Control a Media Player (like Music Assistant) with a generic Tuya Smart Scene Button (Knob).
⚠️ **IMPORTANT: THIS DEVICE HAS TWO MODES** ⚠️
Switch between modes by rapidly tapping the button 3 times.
**1. Normal Mode (Built-in Media Control)**
*Note: If the device does nothing when you first set it up, tap it 3 times to wake up Normal Mode!*
**2. Remote Mode (Custom Actions)**
In this mode, default volume and play/pause logic is ignored. Instead, it executes the custom actions you assign in the fields below for:
- Short Press
- Double Press
- Long Press
- Rotate Right
- Rotate Left
domain: automation
input:
remote:
description: Tuya Smart Scene Button (Knob) to use
selector:
device:
integration: zha
multiple: false
media_player:
description: The media player to control
selector:
entity:
domain: media_player
step_percent:
description: Volume percent change for each step
selector:
number:
mode: slider
min: 1
max: 100
unit_of_measurement: "%"
default: 5
short_press:
name: Remote Mode - Short Press
description: Action to run on single press
default: []
selector:
action: {}
double_press:
name: Remote Mode - Double Press
description: Action to run on double press
default: []
selector:
action: {}
long_press:
name: Remote Mode - Long Press
description: Action to run on long press
default: []
selector:
action: {}
remote_right:
name: Remote mode - Spin Right
description: Action to run on "right spin" in remote mode
default: []
selector:
action: {}
remote_left:
name: Remote mode - Spin Left
description: Action to run on "left spin" in remote mode
default: []
selector:
action: {}
mode: parallel
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
media_player_entity: !input media_player
command: '{{ trigger.event.data.command }}'
mode: '{% if command == ''step'' %} {{ trigger.event.data.args[0] }} {% endif %}'
steps: '{% if command == ''step'' %} {{ (trigger.event.data.args[1] / 12.5 ) | int }} {% endif %}'
step_percent: !input step_percent
- choose:
- conditions:
- '{{ command == ''toggle'' }}'
sequence:
- service: media_player.media_play_pause
entity_id: '{{ media_player_entity }}'
- conditions:
- '{{ command == ''step'' }}'
- '{{ mode == ''StepMode.Up'' }}'
sequence:
- service: media_player.volume_set
volume_level: >
{% set current_vol = state_attr(media_player_entity, 'volume_level') | float(0.0) %}
{% set step = (step_percent / 100) %}
{% set new_vol = current_vol + (step * steps) %}
{{ [new_vol, 1.0] | min }}
- conditions:
- '{{ mode == ''StepMode.Down'' }}'
sequence:
volume_level: >
{% set new_vol = current_vol - (step * steps) %}
{{ [new_vol, 0.0] | max }}
- conditions:
- '{{ command == ''remote_button_short_press'' }}'
sequence: !input short_press
- conditions:
- '{{ command == ''remote_button_double_press'' }}'
sequence: !input double_press
- conditions:
- '{{ command == ''remote_button_long_press'' }}'
sequence: !input long_press
- conditions:
- '{{ command == ''right'' }}'
sequence: !input remote_right
- conditions:
- '{{ command == ''left'' }}'
sequence: !input remote_left
