ZHA - Tuya ZG-101Z/D Smart Knob Automation Blueprint (fork)
This is a forked/modfied version of gogh’s blueprint.
I had trouble with the original as my device was sending slightly different commands.
I also added support for rotation speed through the variable step_multiplier (can be 1 to 5, with 1 being slow, 5 fast).
I’ve paired this with a light cycling blueprint so I can cycle lights and dim them also.
blueprint:
  name: Tuya Rotary Button (ZG-101Z/D ZHA)
  description: >-
    Automate Tuya Smart Knob using ZHA events.
    Faster rotation is reported through the absolute value 'step_multiplier' variable.
  domain: automation
  input:
    smart_knob:
      name: Smart Knob Device
      description: Select your Tuya Smart Knob
      selector:
        device:
          integration: zha
          manufacturer: _TZ3000_gwkzibhs
          model: TS004F
          multiple: false
    action_rotate_clockwise:
      name: Rotate Clockwise
      default: []
      selector:
        action: {}
    action_rotate_anti_clockwise:
      name: Rotate Anti Clockwise
      default: []
      selector:
        action: {}
    action_single_press:
      default: []
      selector:
        action: {}
    action_double_press:
      default: []
      selector:
        action: {}
    action_long_press:
      default: []
      selector:
        action: {}
mode: single
max_exceeded: silent
  # --- ROTATE CLOCKWISE (0) ---
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input smart_knob
      command: step
      params:
        step_mode: 0
  # --- ROTATE ANTI-CLOCKWISE (1) ---
  - platform: event
    event_data:
      command: step
      params:
        step_mode: 1
  # --- SINGLE PRESS (0) ---
  - platform: event
    event_data:
      command: toggle
  # --- DOUBLE PRESS (1) ---
  - platform: event
    event_data:
      command: remote_button_double_press
  # --- LONG PRESS (2) ---
  - platform: event
    event_data:
      command: move_saturation
variables:
  step_size: "{{ trigger.event.data.params.step_size | default(13) | int }}"
  step_multiplier: "{{ [1, [(step_size / 13) | round(0, 'floor') | int, 5] | min] | max }}"
  - choose:
      - conditions:
          - condition: trigger
        sequence: !input action_rotate_clockwise
      - conditions:
        sequence: !input action_rotate_anti_clockwise
      - conditions:
        sequence: !input action_single_press
      - conditions:
        sequence: !input action_double_press
      - conditions:
        sequence:
          - sequence: !input action_long_press
          - wait_for_trigger:
              - trigger: event
                event_data:
                  command: stop_move_step
            timeout:
              hours: 0
              minutes: 0
              seconds: 5
              milliseconds: 0
Also, it’s worth noting that the knob has two modes, Scene mode (factory default) and Remote mode.
This blueprint works only with Remote mode, which has the long press quirk but also has step_size for the step (i.e. rotation) commands that allows slow/fast rotation recognition. Scene mode does not support this and only sends basic left / right command events with no extra data.
To switch modes you’ll need to press the button three times (quite quickly). Look for the attribute_updated event in device activity (or filter zha_event in the developer tools) with switch_mode set to 0.
