ZHA via CC265R and IKEA Tradfri driver + Rodret switch feasible?
Hi everyone!
I’m new to Zigbee, so I don’t know if what I want to achieve even makes sense.
What I would like to do is operate a IKEA Tradfri driver locally with a Rodret switch - regardless of HA running or not.
On top of that I’d like to be able to control the driver from HA. For that purpose, I use an USB connected CC2652R stick.
First I had pairing issues, so I moved the driver closer to the USB stick, which made pairing work. For this, I completely disconnected the driver and moved it to the room where the USB is. When moving back to the desired destination, any action trough HA, like turning the light on/off or dimming, would result in the lights randomly switching on or off or dimming. So I suppose the distance between my USB and the driver is too far to make it work properly?
On top of that, it seems that I’ve lost all functionality when I paired the driver with the Rodret switch again. I reckon that you can only pair with either the Zigbee coordinator or the switch, but not both at the same time?
I have seen other posts about IKEA Zigbee devices, but that didn’t get me anywhere really. Any hints would be highly appreciated :slight_smile:
Cheers
Okay, so physically moving the Tradfri driver fixed the issue regarding the erratic switch behavior. But having it re-paired with ZHA, I lost Rodret switch functionality again.
I managed to pair the Rodret switch with ZHA. Now that I can see it in HA, I tried to bind it to the Tradfri driver. That unfortunately doesn’t work. I see an error in the log about binding failed, but also that the devices are bound: :thinking:
2023-11-25T16:31:41.714355958Z 2023-11-25 17:31:41.711 DEBUG (MainThread) [zigpy.zdo] [0xa762:zdo] cluster: 6 Bind_req --> [28:76:81:ff:fe:26:ba:3b] failed:
2023-11-25T16:31:41.715279137Z 2023-11-25 17:31:41.711 DEBUG (MainThread) [zigpy.zdo] [0xa762:zdo] cluster: 8 Bind_req --> [28:76:81:ff:fe:26:ba:3b] failed:
2023-11-25T16:31:41.715575631Z 2023-11-25 17:31:41.711 INFO (MainThread) [homeassistant.components.zha.websocket_api] Devices bound: source_ieee: [6c:5c:b1:ff:fe:85:ed:05] target_ieee: [28:76:81:ff:fe:26:ba:3b]
Not sure what to make of this, but the binding didn’t work (or, to be more precise: the Rodret won’t turn on or off the lights).
:man_shrugging:
By the way, shouldn’t I be able to se key events from the Rodret whenever I press one in the ZHA debug log?
