ZHA with Digi XBee 3 USB Adapter
I am setting up following XBee 3 USB adapter with HA (fresh install): XU3-A11 - Digi XBee 3 USB Adapter - US, Canada and EMEA | Digi International
Adapter updated with latest firmware using Digi’s XCTU tool:
Digi XBee3 802.15.4
Product Family: XB3-24
Firmware version: 200D (Newest)
Baudrate is set 57600
However when I am trying to add this stick to HA I am getting following error:
Logger: homeassistant.config_entries
Source: config_entries.py:344
First occurred: 11:28:12 AM (1 occurrences)
Last logged: 11:28:12 AM
Config entry 'FT232R USB UART - FT232R USB UART, s/n: ANZ22CEJ - FTDI' for zha integration not ready yet: [Errno 2] could not open port /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_ANZ22CEJ-if00-port0: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_ANZ22CEJ-if00-port0'; Retrying in background
Note I have successfully tested integration with other modules, namely:
Digi XBee3 Zigbee 3.0 TH
Firmware version: 100D (Newest)
As well as TI LaunchPad kit board
LAUNCHXL-CC26X2R1
Where I can modify COM port setting in the HA so that device is recognized?
Replying to @aniva (my own) question regarding
Adapter ships with following Firmware:
Digi XBee3 802.15.4
To get it to work with ZHA need to change firmware using Digi XCTU tool to
and now it works perfectly with HA ZHA, just does not support for example Aqara MCCGQ14 LM ( model: lumi.magnet.acn001 )
Hi Aniva,
I recently flashed this firmware as above and I still cant get ZHA to work with this dongle. Are you able to read your dongle settings using the XCTU program and send me a screen shot of you current settings which got this adaptor to work with your ZHA please? Looking forward to your reply. Thank you.
Regards,
Basheer
