Hello, I am using an " Elelabs Zigbee Raspberry Pi Shield" and have the ZHA integration.
I have some Xiaomi temp sensors which work fine with this configuration. Recently I got a Xiaomi Smart Plug with the intent to use it as a power monitor. When I discover the device, I only see a Switch type entity. I don’t see any other entities responsible for the power values. The plug probably sends the data and I think the problem is with the integration or my configuration. I found the same issue for other zigbee dongle types: Mi Smart Plug doesn't show power consumption in Home Assistant via DeConz · Issue #1513 · dresden-elektronik/deconz-rest-plugin · GitHub
Does anyone have a workaround or a solution?
Thanks!
