been triying to connect to my infrared blaster via zigbee 2 mqtt. Unfortunately that doesn’t start properly, gives me an “Error while starting zigbee-herdsman” message in the log and won’t load the Z2M User Interface.
Config:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: true
mqtt:
server: mqtt://core-mosquitto:1883
user: [myuser]
password: [mypswd]
serial:
port: /dev/ttyACM0
adapter: deconz
My Mosquito config:
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
and a million lines of this in the mosquito log:
023-06-04 09:12:00: Client <unknown> closed its connection.
2023-06-04 09:14:00: New connection from 172.30.32.2:50444 on port 1883.
2023-06-04 09:14:00: Client <unknown> closed its connection.
2023-06-04 09:16:00: New connection from 172.30.32.2:60914 on port 1883.
2023-06-04 09:16:00: Client <unknown> closed its connection.
2023-06-04 09:18:00: New connection from 172.30.32.2:60754 on port 1883.
2023-06-04 09:18:00: Client <unknown> closed its connection.
2023-06-04 09:20:00: New connection from 172.30.32.2:55316 on port 1883.
2023-06-04 09:20:00: Client <unknown> closed its connection.
2023-06-04 09:22:00: New connection from 172.30.32.2:35508 on port 1883.
2023-06-04 09:22:00: Client <unknown> closed its connection.
2023-06-04 09:24:00: New connection from 172.30.32.2:49074 on port 1883.
2023-06-04 09:24:00: Client <unknown> closed its connection.
2023-06-04 09:24:36: Saving in-memory database to /data//mosquitto.db.
Any Ideas what it could be? My Zigbee USB stick works fine to communicate with other zigbee devices.
