Zigbee bulb doesn't show in the Add Device GUI
Hello Friends,
When trying to add a new Zigbee bulb by Innr I’m getting the following messages in the HA ZHA log, and the bulb is not showing up in the HA GUI.
Feeding watchdog
[<Task pending name='device-availability-checker_DeviceAvailabilityChecker' coro=<periodic.<locals>.scheduler.<locals>.wrapper() running at /usr/local/lib/python3.13/site-packages/zha/decorators.py:78> cb=[set.remove()]>] executing periodic task [zha.application.helpers::DeviceAvailabilityChecker.check_device_availability]
Device availability checker interval starting
Checking device availability
[0x1A12](RS 226): last_seen is 77830.23803400993 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x1A12](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0x8AA5](RS 226): last_seen is 77828.35127949715 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x8AA5](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0xE86E](RS 226): last_seen is 77835.66226410866 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0xE86E](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0x1B2F](RS 226): last_seen is 77846.18728280067 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x1B2F](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0xC504](RS 226): last_seen is 77781.8755800724 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0xC504](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0x8083](RS 226): last_seen is 68897.96572828293 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x8083](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0xD2F1](RS 226): last_seen is 68904.13870286942 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0xD2F1](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0x733C](RS 226): last_seen is 69202.52195191383 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x733C](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0xFF10](RS 226): last_seen is 69201.86472272873 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0xFF10](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0x0A72](RS 226): last_seen is 69226.53100633621 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x0A72](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0x383C](RS 226): last_seen is 68856.84124231339 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x383C](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0x004D](RS 226): last_seen is 69229.23820447922 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x004D](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0xEEA3](RS 226): last_seen is 69173.4737625122 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0xEEA3](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0x7E82](RS 226): last_seen is 69223.95436048508 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0x7E82](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0xE247](RS 226): last_seen is 69226.05764341354 seconds ago and ping attempts have been exhausted, marking the device unavailable
[0xE247](RS 226): Update device availability -  device available: False - new availability: False - changed: False
[0xD0E3](lumi.sensor_magnet.aq2): Device seen - marking the device available and resetting counter
[0xD0E3](lumi.sensor_magnet.aq2): Update device availability -  device available: True - new availability: True - changed: False
[0xEB70](lumi.sensor_magnet.aq2): Device seen - marking the device available and resetting counter
[0xEB70](lumi.sensor_magnet.aq2): Update device availability -  device available: True - new availability: True - changed: False
Device availability checker interval finished
Is there a way to fix this?
Any help will be greatly appreciated :pray:
Is the bulb getting power? It’s a common error, smart bulb in a socket but the switch on the socket is not turned on. So smart bulb isn’t so smart without power.
And to add to this, if this is a 3-way lamp you may find that not all “clicks” work for joining. I have no idea why, but I have two lamps that have only been able to work for joining when the bulbs are powered by the first “click” of turning the lamp switch.
The lightbulb is turned on.
The log only starts showing these messages after I turn the bulb ON.
It’s turned on, but is the bulb in pairing mode? It should be blinking if it is
I have the bulb connected to a simple cable switch I built for times I need to add/re-add light bulbs, without interrupting other bulbs in the process.
