I have six Thirdreality Zigbee Smart buttons.
Some are connected to lights and some my workshop equipment (turn on my dust collector with a press of a button) using a zigbee based plug.
When pressed it turns on the plug’s power or turns off.
My problem is that every time I restart home assistant, all the devices associated with the buttons turn on.
I did find some code that works well returning the monitoring and returning the state of a light to its original state after restart.
Below is the code I started to use because this light has a button associated with it.
It took me awhile t figure out it was not the switch, but has to do with the button.
Any help/directions appreciated.
# MONITOR MASTER BEDROOM LIGHT STATUS 2023Dec20 #
- id: "a55f71ba-7be4-4b8e-ba40-1feea714996c"
alias: 'Light: Monitor Light Status Master Bedroom Dimmer'
description: 'Light: Monitor Light Status Master Bedroom Dimmer'
- platform: device
type: changed_states
device_id: 805e1a3607391dcf3fc85acc378ee93b
entity_id: light.switch_master_bedroom_dimmer
domain: light
condition: []
- if:
- condition: device
type: is_on
domain: light
then:
data: {}
entity_id: input_boolean.master_bedroom_light_dimmer
else:
- service: input_boolean.turn_off
data: {}
mode: single
# RESTORE MASTER BEDROOM LIGHT STATUS 2023Dec20 #
- id: "89f8d771-aea9-4d29-84b1-21ec13ad886a"
alias: 'Light: Restore Light Status at Restart'
description: 'Light: Restore Light Status at Restart'
- platform: homeassistant
event: start
condition: []
- if:
- condition: state
state: 'on'
then:
- type: turn_on
domain: light
else:
- type: turn_off
domain: light
mode: single
