Hi - I recently discovered that my Tuya C02Z CCT LED strip controller does not support user-defined transition times, which makes use with a smart dimmer via Home Assistant (light.turn_on “transition” duration feature) in a manner similar to Phillips Hue challenging. Is anyone aware of a Zigbee CCT controller that does offer this feature? If not, I’ll probably end up going the Wi-fi route, but for this purpose Zigbee is definitely preferred. Thanks!
Gledopto’s do
Could you please clarify the model number(s)? GL-C-006P? GL-C-003P? All of them?
Thanks!
I would assume all of them, certainly the GL-C-008P and GL-C-008-1ID
Thanks for the advice. Order placed!
I’m using Gledopto GL-C-003P (Firmware Version 20451203) with zigee2mqtt.
Transition time is working for my when turning on/off the device. Exception: setting transition to 0 does not result in immidiatly turning on/off => there is still a transition of 1 sec.
BUT transition does not work for color changes => this takes always about 1 sec.
Can anybody confirm or disagree…
