Zigbee DconZ with ConBeeII stoped working
I cannot get my ConBeeII stick to connect to network. I was working a week ago. I am running the latest HA 2022.4.7. My HA is running in a VM on unraid. It sees the Dresden USB stick but fails to connect to Network. Here are my log files.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] firmware.sh: executing...
[18:12:45] INFO: GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
Path             | Vendor | Product | Serial     | Type
/dev/ttyACM0     | 0x1CF1 | 0x0030  |            | ConBee II
/dev/ttyACM1     | 0x1CF1 | 0x0030  | DE2495005  | ConBee II
[cont-init.d] firmware.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] novnc.sh: executing...
[cont-init.d] novnc.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[18:12:45] INFO: Websockify waiting for VNC to start
[services.d] done.
[18:12:45] INFO: Running the deCONZ OTA updater...
[18:12:45] INFO: Running the OSRAM LEdvance OTA updater...
[18:12:45] INFO: Running the IKEA OTA updater...
[18:12:45] INFO: Starting VNC server (local/yes)...
[18:12:46] INFO: Starting websockify...
WebSocket server settings:
  - Listen on 127.0.0.1:5901
  - Flash security policy server
  - Web server. Web root: /usr/share/novnc
  - No SSL/TLS support (no cert file)
  - proxying from 127.0.0.1:5901 to 127.0.0.1:5900
18:05:36:427 DDF: doc:path: samsung/samjin_button_switch.md
18:05:36:427 DDF: manufacturername: $MF_SAMJIN
18:05:36:427 DDF: md:known_issues:
18:05:36:427 DDF: modelid: button
18:05:36:427 DDF: product: Samsung Button (IM6001-BTP01)
18:05:36:427 DDF: schema: devcap1.schema.json
18:05:36:427 DDF: status: Silver
18:05:36:428 DDF: subdevices:
18:05:36:428 DDF: loaded resource item descriptor: attr/lastseen
18:05:36:428 DDF: loaded resource item descriptor: attr/manufacturername
18:05:36:428 DDF: loaded resource item descriptor: attr/modelid
18:05:36:428 DDF: failed to load resource item descriptor: attr/mode
18:05:36:428 DDF: loaded resource item descriptor: attr/name
18:05:36:428 DDF: loaded resource item descriptor: attr/swversion
18:05:36:428 DDF: loaded resource item descriptor: attr/type
18:05:36:428 DDF: loaded resource item descriptor: attr/uniqueid
18:05:36:428 DDF: loaded resource item descriptor: config/battery
18:05:36:428 DDF: loaded resource item descriptor: config/on
18:05:36:428 DDF: loaded resource item descriptor: config/pending
18:05:36:428 DDF: loaded resource item descriptor: config/reachable
18:05:36:428 DDF: loaded resource item descriptor: state/lastupdated
18:05:36:428 DDF: loaded resource item descriptor: state/buttonevent
18:05:36:428 DDF: loaded resource item descriptor: config/offset
18:05:36:428 DDF: loaded resource item descriptor: state/temperature
18:05:36:447 parent process s6-supervise
18:05:36:447 gw run mode: docker/hassio
18:05:36:447 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
18:05:36:449 DB sqlite version 3.27.2
18:05:36:449 DB PRAGMA page_count: 42
18:05:36:449 DB PRAGMA page_size: 4096
18:05:36:449 DB PRAGMA freelist_count: 0
18:05:36:449 DB file size 172032 bytes, free pages 0
18:05:36:449 DB PRAGMA user_version: 8
18:05:36:449 DB upgrade to user_version 9
18:05:36:487 DB write sqlite user_version 9
18:05:36:501 DB PRAGMA user_version: 9
18:05:36:501 DB cleanup
18:05:36:501 DB create temporary views
18:05:36:506 Started websocket server on 0.0.0.0, port: 8081
18:05:36:507 [INFO] - Found file containing button maps. Parsing data...
18:05:36:511 [INFO] - Button maps loaded.
18:05:36:512 found node plugin: libde_rest_plugin.so - REST API Plugin
18:05:36:512 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
18:05:37:286 OTAU: create 1189-003C-01056400.zigbee
18:05:37:300 OTAU: create 1189-003C-01056400.zigbee
18:05:37:309 OTAU: create 1189-0034-01056400.zigbee
18:05:37:317 OTAU: create 1189-0034-01056400.zigbee
18:05:37:325 OTAU: create 1189-0034-01056400.zigbee
18:05:37:333 OTAU: create 1189-0033-01056400.zigbee
18:05:37:341 OTAU: create 1189-0033-01056400.zigbee
18:05:37:368 OTAU: create 1189-00A0-02146550.zigbee
18:05:37:386 OTAU: create 1189-008C-02056550.zigbee
18:05:37:388 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
18:05:37:531 dlg action: Read binding table
18:05:38:417 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2495005-if00 / serialno: , ConBee II
18:05:38:460 Skip idle timer callback, too early: elapsed 927 msec
18:05:39:000 device state timeout ignored in state 2
18:05:40:159 device state timeout ignored in state 2
18:05:40:319 device state timeout ignored in state 2
18:05:40:478 device state timeout ignored in state 2
18:05:40:639 device state timeout ignored in state 2
18:05:40:798 device state timeout ignored in state 2
18:05:40:959 device state timeout ignored in state 2
18:05:41:119 device state timeout ignored in state 2
18:05:41:279 device state timeout ignored in state 2
18:05:41:438 device state timeout ignored in state 2
18:05:41:599 device state timeout ignored in state 2
18:05:41:781 device state timeout (handled)
18:05:41:859 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
18:05:41:859 device state timeout ignored in state 1
18:05:42:509 Announced to internet https://phoscon.de/discover
18:05:44:909 DEV Tick.Init: booted after 8000 seconds
18:05:51:935 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26660700.bin.GCF
18:05:56:426 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2495005-if00 / serialno: , ConBee II
18:05:57:426 start reconnect to network
18:05:57:999 device state timeout ignored in state 2
18:05:58:158 device state timeout ignored in state 2
18:05:58:319 device state timeout ignored in state 2
18:05:58:479 device state timeout ignored in state 2
18:05:58:638 device state timeout ignored in state 2
18:05:58:799 device state timeout ignored in state 2
18:05:58:959 device state timeout ignored in state 2
18:05:59:119 device state timeout ignored in state 2
18:05:59:278 device state timeout ignored in state 2
18:05:59:439 device state timeout ignored in state 2
18:05:59:598 device state timeout ignored in state 2
18:05:59:758 device state timeout (handled)
18:05:59:839 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
18:05:59:839 device state timeout ignored in state 1
I’m having the same issue. Did you solve it?
I have not solved the issue. I moved it to a raspberry pi off of the Unraid server, still running HASSIO VM. Not what on Unraid caused the issue.
It looks like it can’t find the dongle, and/or that the dongle has moved from one port (ACM0) to another (ACM1) and deCONZ is trying the wrong one.
