ZigBee, deCONZ ConBee USB, HA can't connect
Since I upgraded to Home Assistant 0.66.0 I can’t connect to my “fake” hue bridge (deCONZ-GW / Conbee).
I can’t figure out what I’m doing wrong…(it worked fine before).
My set up:
deCONZ-GW
Vendor dresden elektronik
Product ConBee
Version 2.05.19 / 3/18/2018
Firmware 261F0500
This USB stick is running on a Raspberry Pi with Debian Stretch.
On my main server I’m running Home Assistant - 0.66.0 (as a Docker container).
After opening up the gateway for 60 seconds (tried both via Phoscon App or the other web interface - same result), and after have pressed the “configure” Hue in HA, and the “I have pressed the button” icon, I get this error:
“Unknown error connecting with Hue bridge at 192.168.1.XXX
File “/usr/src/app/homeassistant/components/hue/init.py”, line 192, in async_setup
await api.initialize()
File “/usr/local/lib/python3.6/site-packages/aiohue/bridge.py”, line 48, in initialize
self.scenes = Scenes(result[‘scenes’], self.request)
KeyError: ‘scenes’”
Any clues?
Have you tried using the deconz component instead of the hue component (which got a rewrite for 0.66).
Doh!
I had no clue that had changed. Wish I would have known that several hours ago… I’ll give it a try, I’m pretty sure this will solve the problem…
Thanks!
I tried and all works like a charm - thanks!
