Zigbee device read values every x minute
I want to write a script that read every x minutes the value of the device. For example the illuminance or temperature. I have aqara motion sensor, which mesure also the illuminance, but it does not update hassio every x seconds. It sends the date to hassio only when it detected the movement.
So want to write some kind of polling.
If using Zigbee2MQTT
zigbee2mqtt/[FRIENDLY_NAME]/get #
This is the counterpart of the set command. It allows you to read a value from a device. To read e.g. the state of a device send the payload {"state": ""}. What you can /get is specified on the device page under the “Exposes” section.
Illuminance (numeric) #
Measured illuminance in lux. Value can be found in the published state on the illuminance property. It’s not possible to read (/get) or write (/set) this value. The unit of this value is lx.
Whatever you get from polling, it will not be the current value, but the last update.
I am not using Zigbee2MQTT. Using ZHA with ConbeeII
Doesn’t matter, as @m0wlheld wrote you will not be able to get the current value from the sensor. Apart from that illuminance from the this montion sensor is pretty useless, beter take a look at the xiaomi light sensor.
The Philips Hue Motion sensor reports illumination and temperature independent of motion detection.
Ok got it. Low cost sensor do not provide details
€ 9.74 is not expensive
yeh but the one i got has: illuminance, occupancy and motion
