Zigbee device shows up in Zigbee2MQTT but not in HA entities
HA running on Raspberry Pi.
Zigbee2MQTT & Mosquitto Broker.
Lots of Zigbee devices running just fine.
I added a Sengled Remote (E1E-G7F) and it shows up correctly in Z2M integration and I can see MQTT messages on button press.
The device does not show up in HA entities, so can’t add it to a dashboard or add it to automations or blueprints.
Thoughts?
Which step did I miss?
In the mqtt devices, does it show it.
Assuming you have Z2M 2.0, there is no action sensor anymore, so you’ll have to find an updated blueprint.
The remote does show in in the Z2M device list.
I can see MQTT messages in MQTT Explorer
I’m running Z2M V2.1.1, so yes there are some changes to the action sensors that I need to look into.
For now, the fix seems to be:
Zigbee2MQTT->Settings->Home Assistant integration
Enable: “Home Assistant experimental event entities” and/or “Home Assistant legacy action sensors”.
After that, my the remote shows up in entities list and can be used as usual in HA.
