Zigbee devices not updating after 2025.02.3
Hello all, I am using the default ZHA integration, and after the 2025.02.3 update, none of my zigbee devices are working. Zwave seems to work ok. Anyone else have this problem? The states show as of the moment before the update.
Both powered and battery devices are not updating. Switching them on and off from HA results in “failed” error. Manually switching them on and off does not reflect in HA.
I am using HAOS on proxmox. Have tried restarting everything
It looked like some of my routers went down after the update. I disconnected those routers, but ZHA would only re-add one of them, the other two refuse to pair. As a result, now my battery devices are going from unresponsive to offline.
The routers in question were the Aeotech Range Extender Zi (e.g. zigbee version).
I extended the timeout for the battery powered devices to 21600 from 10800 seconds, hopefully this will help and more of my devices will find their way back to my network. I’m not looking forward to repairing everything manually…
After removing the Aeotec Range Extender Zi and replacing with a bunch of ThirdReality plugs I had lying around, waiting overnight, then going into ZHA and forcing a “reconfigure” for each device, most have come back online. A few that didn’t required manual re-pairing, but for now I seem to be OK.
I saw 2025.02.4 just came out - that’s a quick followup, I wonder if there was an issue that needed to be resolved related to this.
