If you are running HAOS this should not happen…
If you are running an advanced version of HA and you are having problems I suggest you re-think your situation.
If put in the right place, this might help, but it is going to have
It is a normal (official) version of HAOS. Basically virgin.
I have the same stick working on a Raspi 4 and I remember at the beginning this happened as well but worked around the 5th time or so. This one does not.
Will return it and try another one.
When I enter stuff like “(sudo) adduser second_user…” in terminal, I get “unknown user”, “unknown group” etc.
I was unable to integrate the P-type. The E-type was integrated without any issues out of the box, though.
In case you are using HA on a Raspi 4/5: buy the E-version! I do not know how to fix the problem for P-type and I have not found a solution online. If anyone knows, please share your wisdom!
