I’ve now got my new Zigbee co-ordinator setup and working well , but one thing I cannot sort and something I would like to ask for some advise on please.
When I open the Zigbee to list the devices I get this error and I don’t know what it means.
zh:ember:ezsp: Received network/route error ROUTE_ERROR_ADDRESS_CONFLICT for “0”.
I have check the config of the co-ordinator to the best of my knowledge (which is limited on Zigbee) and everything looks ok.
Hi , not exactly… What happened was I was running on 32 bit hardware with a supervisor install.
When the depreciation notice was released I re-purposes an Intel mini pc and did a new install of HAOS but needed a new Zwave and Zigbee dongle. I was advised on this forum to use a Zigbee co-ordinator instead, which is what I did.
So basically its a new fresh install with new hardware and all the devices reset to factory and then added.
Just to add the core firmware is 2.9.4 the latest and the Zigbee co-ordinator is revision 20250220 again the latest. I dont have any slow connections or drop out thou and everything is working fine
Thank you francisp Francis , I read through the article and the point I took away that might help me was the use of the ember driver. It seemed to suggest using the eszp driver instead. My concern is that if I change this in my Zigbee configuration file I might loose the zigbee network and be in a position of having to try either a restore or a rebuild and re-add of 30+ devices.
Can anyone tell if if its safe to change the driver or not …
Yeh that’s where my head is. I’ve recently had two major outages of Zwave where I had to rebuild that network and then I had to replace the hardware, so I don’t want to risk screwing up the Zigbee network now that it’s working well.
