Zigbee Failed Setup - Home Assistant Yellow
I’m not super-techie but can generally navigate HA. I’ve had HA Yellow setup for about 18 months. Zigbee has always been problematic. Basically I’ve had to manually reload every 48 hours to so. Not ideal, but it worked. Now it’s not and I have a couple of questions.
  1. Since I’ve tried to reconfigure, do I have the correct basic setting. This is what I’m doing.
-Migrate or reconfigure
-Re-configure the current radio
-/dev/ttyAMA1 - Yellow Zigbee module - Nabu Casa
-Submit
-Pick your Zigbee radio type
-EZSP = Silicon Labs EmberZnet protocol: Elelabs, HUSBZB-1, Telegenesis
-Submit
-Enter the serial port setting (I just use what it defaults to)
-Serial device path*
-(default setting)
-Port speed*
-(default setting)
-Data flow control
-software (default)
-submit
And it returns with Failed to connect error.
  1. I only run Aqara devices through Zigbee and I’m considering the following:
    a. install Matter based Aqara hub
    b. install Zigbee dongle
