Hello @dandanache is it possible to view more then one z2mqtt networks in one HA zigbee map instance as add-on? Now I have multiple z2mqtt networks at home but the zigbee map add-on only shows me the network connected in my zigbee2mqtt proxy add-on.
Should I remove the proxy and work with several maps in the configuration.yaml of HA?
I would keep your current setup, the Zigbee add-on (integration) will register the panel for one of your Z2M instances. To add an extra panel for the second instance, you can add this to your config/configuration.yaml:
Yes there is. I’ll see if I can make that nicer, currently this is a hack. I see that the integration uses this panel property webcomponent_name: zigbee-map-panel to get around it. Edit: does not work.
Do you really need more than 4 panels (zigbee-map, zigbee-map-1, zigbee-map-2, zigbee-map-3)?
Well @dandanache you would really help me yes if you could make it to 5 panels.
I have split up my z2mqtt network to 5 seperate z2mqtt networks which made my zigbee more stable now.
I have left the zigbee proxy add-on so that one works in your zigbee map but then I have 4 extra networks which now are included in the configuration.yaml
Or can I use these as the extra maps in the configuration.yaml beside the one
If you set Data source = Zigbee2MQTT in the integration options, it will register the panel as “zigbee-map-z2m” so it frees up “zigbee-map” to be used in your configuration.yaml.
Go to Settings → Devices & services → Zigbee Map → Cog wheel button → Set “Data source” to “Zigbee2MQTT”. This will register a panel for one of your Z2M instances.
Register panels for the remaining four Z2M instances using configuration.yaml:
That’s a great way to deal with it, although I have to say, that in the meantime, I have created some button cards to keep most of the sidebar entries ‘out of reach’ for the normal user:
Thanks this is AMAZING work! I hope it makes its way into the official HA release.
Q: Is the background image setting device specific? Just set it up on my laptop and dragged the devices into position with the Persist option enabled. Looks fantastic but when I load on my phone it doesn’t have the settings or background?
Another observation I found was that when clicking a router/repeater device (may also happen with end devices too), very frequently they would rapidly relocate/move way off my floorplan. Not sure why? Would be great if we could lock the nodes into a permanent position once finally dragged into place. Also being able to have the ability to save the node locations into the config rather than browser would be cool. Not sure I have the patience to drag ~140+ nodes around on my mobile. On the laptop it was surprisingly quicker than I though it would be.
Edit: So I read the manual and " * Click or tap a fixed node to reset its position." - the issue is after I’ve dragged the node into position and if I click the node to inspect the neighbours, it resets position which is the annoying part.
Many thanks! Something weird was going on when I upgraded. HACS didn’t find the new version so I simply re-downloaded the new version via HACS. But then the map About page still referred to the old version. I ended up removing the integration and adding it back again and possibly rebooting. I did have to drag and drop All my devices again after the update but all good now.
Is it possible to add a lock button to avoid accidentally dragging a device after they’ve all been correctly placed? I have about 145 devices so it’s easy for me to accidentally move a device when panning or zooming.
The next time, should there be a next time, you experience that behavior, if you haven’t tried this before removing the integration and reinstalling it, try a simple browser cache flush. Instructions have been posted in this thread several times, but to reiterate on a chrome browser using windows - press F12 to bring up Chrome Developer screen, then right click on the reload page button next to the address bar, a drop down appears, select Empty Cache and Hard Reload.
Good point! I should have mentioned in the release notes that node positions are reset after the update.
That’s a reasonable feature request. I’ll look into adding something like that
In theory this shouldn’t be necessary anymore when the app is installed via HACS/GPM, since each new release appends a different ?v=x.y.z cache‑busting query parameter to the JavaScript URL.
That said, it’s possible something isn’t behaving as expected since people are still running into the caching issue.
