i am trying to add USB SSD HDD to Raspberypi4.
Now all works OK. I use Mosquito + zigbe2mqtt (edge).+ and Hassio 5.9 32bit on SD card.
I use USB Electrolama zig-a-zig-ah! (zzh!) ( CC26X2R1) with Coordinator FW: CC26X2R1_20201026.zip
So i installed Hassio 5.9 64bit on SSD drive.
Than i restored snapshot that i took before on SD running system.
After restore all looks ok. BUT my zigbee network does not work as it should.
I can see i receive Aqara action clicks and temperatures, but my Tuya device does not work anymore.
I use couple of TS0601 and TS0011 and TS0012.
When i try to repair this Tuya devices i see message: DEVICEID has left the network.
After that nothing happens. Even when i try to repair again, i get same mssage.
It is impossible to repair it again or make it work.
If i connect old SD card to raspberrypi4 all works OK.
Is there something that must be done for CC26X2R1 devices ?
In logfile i can see for Tuya device messages like: …MAC transaction expired. Or …no network route.
It is no problem to configure whole zigbee network again, but even if i try with blank database.db i cannot pair Tuya devices. I always see …has left the network and finished.
