ZigBee Nous A1Z switch keeps turning off by itself
I have a few ZigBee Nous A1Z switches that keep turning off for no reason. HA version: 2025.4.1
There is no automation for it, and there is nothing special in the logs.
In the picture below, you can see the switch turning off for no reason. After that, I switched it on using a physical switch, and later, it went off again.
What could be a reason for that?
Since there is also times when the device is unavailable, it seems communication problems might be the culprit, or the device loosing power.
If there is no cause listed in HA, it can be an event originating from the device. Either control from the device itself, or power loss, followed by the default behaviour of the device when power is restored.
But if it is communication problems, the list of possible causes is very long. The obvious: make sure your zigbee stick is on an extension cord, away from other devices. Make sure you have enough zigbee router devices. The k if your Zigbee channel overlaps with your wifi channels (be aware: they use different numbering systems). Never cut power from zigbee router devices. (Do you have other bulbs or mains powered things that get cut from power?).
The Home Assistant Cookbook has lots of troubleshooting tips.
This is a good place to start:
Unavailable is only because I’ve disconnected the plug. I have a few such plugs and most of them (not all) had the same problem at that day, around 12-14. The plug should not turn off, when it has no conectivity (I really hope so), so there must be something what triggers it…
In order to fight this problem I’ve created automation, that will turn those switches on every 30 minutes. This works fine as you can see below, however short time after going on, switch goes off. And this happens for a few switches from 12 to 14, however no exactly at the same time, but short time after switching on.
One switch goes off arount 13:01, this is the log:
2025-04-10 12:55:00.065 INFO (MainThread) [homeassistant.components.automation.maciek_air_humidifier_off_at_45] Maciek -  Air Humidifier - Off: Running automation actions
2025-04-10 12:55:00.065 INFO (MainThread) [homeassistant.components.automation.maciek_air_humidifier_off_at_45] Maciek -  Air Humidifier - Off: Executing step device automation
2025-04-10 13:00:00.274 INFO (MainThread) [homeassistant.components.automation.plugs_power_measurement_on] Plugs Power Measurement On: Running automation actions
2025-04-10 13:00:00.275 INFO (MainThread) [homeassistant.components.automation.plugs_power_measurement_on] Plugs Power Measurement On: Executing step call service
2025-04-10 13:00:00.450 INFO (MainThread) [homeassistant.components.automation.maciek_air_humidifier_off] Artur - Air Humidifier - Off: Running automation actions
2025-04-10 13:00:00.450 INFO (MainThread) [homeassistant.components.automation.maciek_air_humidifier_off] Artur - Air Humidifier - Off: Executing step device automation
2025-04-10 13:02:14.242 INFO (MainThread) [custom_components.hacs] HACS is enabled
2025-04-10 13:02:14.256 INFO (MainThread) [custom_components.hacs] <HacsData restore> Restore started
At 11:30 it also goes off, and there is a communication error im log:
2025-04-10 11:30:00.424 INFO (MainThread) [homeassistant.components.automation.artur_air_humidifier_on_at_43] Artur - Air Humidifier - On: Running automation actions
2025-04-10 11:30:00.425 INFO (MainThread) [homeassistant.components.automation.artur_air_humidifier_on_at_43] Artur - Air Humidifier - On: Executing step device automation
2025-04-10 11:30:05.711 ERROR (MainThread) [homeassistant.components.automation.plugs_power_measurement_on] Plugs Power Measurement On: Error executing script. Error for call_service at pos 1: Failed to send request: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
2025-04-10 11:30:05.712 ERROR (MainThread) [homeassistant.components.automation.plugs_power_measurement_on] Error while executing automation automation.plugs_power_measurement_on: Failed to send request: Failed to deliver message: <sl_Status.ZIGBEE_DELIVERY_FAILED: 3074>
2025-04-10 11:32:14.121 INFO (MainThread) [custom_components.hacs] HACS is enabled
2025-04-10 11:32:14.133 INFO (MainThread) [custom_components.hacs] <HacsData restore> Restore started```
I’ve created ping timer, that sends turn on signal every minute. Now they stay on. It looks like they go off, when there is no communication. Not sure why the plug cannot remember that is was suppose to be on :frowning:
Are you loosing power?
Try to change the setting for “Power outage memory” (on/off/restore) on the device.
Bildschirmfoto vom 2025-04-17 07-06-27
I do not loose power. I have only this setting:
Where is “Power outage memory” located?
It’s “Power on state” on your site.
Depending on the screenshots it seems to be that the power off state is triggered 9 hours after switching on any time. Isn’t it? In that case check your automations. Maybe there is another trigger? Enable the debug option for ZHA can help to identify the problem.
These devices having a countdown timer as well. Maybe it is active on the device? Can’t tell you how to check it with ZHA.
Updating firmware is useful as well. The stock versions are not on the lastest firmware and they had some issues as I remember. Check ZHA
Posting automation config is useful for help. :slight_smile:
“Power On” state is “On”.
This plug should not have automation; it should always be on to measure power consumption.
I’ve created automation. It runs once a minute and switches it on. It helps, and now it stays on. But I do not like this solution,
There is no update for Nous.
I have a lot of Nous devices (15-20) since years and I never had an issue with them.
Zigbee devices depending on a lot of things … the stick and the firmware on it, ZHA vs. Z2M, the network quality and so on.
As I said it seems to be that some other problem is ongoing. I guess it’s not the device itself.
I also have this problem with the NousA1Z sockets, and I’m almost sure that the problem comes from the electrical grid which is saturated due to the fact that there are too many solar panels in my street. When the grid reaches 260V the sockets switch off. It could also be logical that this happens between 12 p.m. and 2 p.m. because that’s when production is the highest…
I also faced the issue with a Nous A6Z outdoor socket at about 2:30 pm. Great: I‘m on vacation and now the connected device is turned off the whole time… do you know, whether the socket turns on automatically again? It is off since about one day.
