Zigbee Power Extension / Strip (_TZ3000_gdyjfvgm)
Hi, anyone can help me with this device?
I tried connected it to ZHA, and it is being recognized as 5 switch device in HA.
But when I set any of the switch ON, all other switch turn ON & vice versa.
Also the electrical measurement cannot be read by HA.
I have found someone using Z2M have solved the problem but I prefer to maintain using ZHA.
Below is the link:
Also I have tried implement zha quirk but still no avail. I tried to adjust according to this file.
Attached here is my file quirk I added for a test. But when I added the quirk, the power strip cannot be controlled thru HA, even though the switch are showed on HA. It keep show failed to establish connection when either press ON / OFF.
Below is my edited quirk file ( I don’t know if I the quirk file is correct btw)
"""TS011F plug."""
from zigpy.profiles import zha
from zigpy.quirks import CustomDevice
from zigpy.zcl.clusters.general import (
    Basic,
    GreenPowerProxy,
    Groups,
    Identify,
    OnOff,
    Ota,
    Scenes,
    Time,
from zigpy.zcl.clusters.homeautomation import ElectricalMeasurement
from zigpy.zcl.clusters.smartenergy import Metering
from zhaquirks.const import (
    DEVICE_TYPE,
    ENDPOINTS,
    INPUT_CLUSTERS,
    MODEL,
    MODELS_INFO,
    OUTPUT_CLUSTERS,
    PROFILE_ID,
from zhaquirks.tuya import (
    TuyaNewManufCluster,
    TuyaZBE000Cluster,
    TuyaZBElectricalMeasurement,
    TuyaZBExternalSwitchTypeCluster,
    TuyaZBMeteringCluster,
    TuyaZBOnOffAttributeCluster,
from zhaquirks.tuya.mcu import EnchantedDevice
class Plug_4AC_2USB_cfnprab5(EnchantedDevice):
    """Tuya 4 outlet + 2 USB surge protector with restore power state support."""
    signature = {
        MODEL: "TS011F",
        ENDPOINTS: {
            # <SimpleDescriptor endpoint=1 profile=260 device_type=266
            # device_version=1
            # input_clusters=[0, 3, 4, 5, 6, 1794, 2820, 57344, 57345]
            # output_clusters=[10, 25]>
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.ON_OFF_PLUG_IN_UNIT,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Identify.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    OnOff.cluster_id,
  		    ElectricalMeasurement.cluster_id,
		    Metering.cluster_id,
                    TuyaZBE000Cluster.cluster_id,
                    TuyaZBExternalSwitchTypeCluster.cluster_id,
                OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
            # <SimpleDescriptor endpoint=2 profile=260 device_type=266
            # device_version=1
            # input_clusters=[4, 5, 6, 57345]
            # output_clusters=[]>
            2: {
                INPUT_CLUSTERS: [
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    OnOff.cluster_id,
                OUTPUT_CLUSTERS: [],
            # <SimpleDescriptor endpoint=3 profile=260 device_type=266
            # device_version=1
            3: {
                INPUT_CLUSTERS: [
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    OnOff.cluster_id,
            # <SimpleDescriptor endpoint=4 profile=260 device_type=266
            # device_version=1
            4: {
                INPUT_CLUSTERS: [
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    OnOff.cluster_id,
            # <SimpleDescriptor endpoint=5 profile=260 device_type=266
            # device_version=1
            5: {
                INPUT_CLUSTERS: [
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    OnOff.cluster_id,
            # <SimpleDescriptor endpoint=242 profile=41440 device_type=97
            # device_version=1
            # input_clusters=[]
            # output_clusters=[33]>
            242: {
                PROFILE_ID: 41440,
                DEVICE_TYPE: 97,
                INPUT_CLUSTERS: [],
                OUTPUT_CLUSTERS: [GreenPowerProxy.cluster_id],
    replacement = {
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
  		    ElectricalMeasurementCluster,
		    MeteringCluster,
                    TuyaZBE000Cluster,
            2: {
                INPUT_CLUSTERS: [
                    Groups.cluster_id,
                    Scenes.cluster_id,
            3: {
                INPUT_CLUSTERS: [
                    Groups.cluster_id,
                    Scenes.cluster_id,
            4: {
                INPUT_CLUSTERS: [
                    Groups.cluster_id,
                    Scenes.cluster_id,
            5: {
                INPUT_CLUSTERS: [
                    Groups.cluster_id,
                    Scenes.cluster_id,
            242: {
                PROFILE_ID: 41440,
                DEVICE_TYPE: 97,
                INPUT_CLUSTERS: [],
Power strip detail:
Device signature:
  "node_descriptor": {
    "logical_type": 1,
    "complex_descriptor_available": 0,
    "user_descriptor_available": 0,
    "reserved": 0,
    "aps_flags": 0,
    "frequency_band": 8,
    "mac_capability_flags": 142,
    "manufacturer_code": 4417,
    "maximum_buffer_size": 66,
    "maximum_incoming_transfer_size": 66,
    "server_mask": 10752,
    "maximum_outgoing_transfer_size": 66,
    "descriptor_capability_field": 0
  "endpoints": {
    "1": {
      "profile_id": "0x0104",
      "device_type": "0x010a",
      "input_clusters": [
        "0x0000",
        "0x0003",
        "0x0004",
        "0x0005",
        "0x0006",
        "0x0702",
        "0x0b04",
        "0xe000",
        "0xe001"
      "output_clusters": [
        "0x000a",
        "0x0019"
    "2": {
      "input_clusters": [
        "0x0004",
        "0x0005",
        "0x0006",
        "0xe001"
      "output_clusters": []
    "3": {
      "input_clusters": [
        "0x0004",
        "0x0005",
        "0x0006",
        "0xe001"
    "4": {
      "input_clusters": [
        "0x0004",
        "0x0005",
        "0x0006",
        "0xe001"
    "5": {
      "input_clusters": [
        "0x0004",
        "0x0005",
        "0x0006",
        "0xe001"
    "242": {
      "profile_id": "0xa1e0",
      "device_type": "0x0061",
      "input_clusters": [],
        "0x0021"
  "manufacturer": "_TZ3000_gdyjfvgm",
  "model": "TS011F",
  "class": "zigpy.device.Device"
Btw, I am still newbie in this area. Do follow up for additional detail / info, so that we can solve this together.
Thank you.
