Hi there,
I have some trouble since a longer time that some of my Zigbee devices doesn’t work well.
For example the window sensor from Aquara → I just two in one room and it changes to open/close not every time I open/close the window.
Now I found the visualisation overview from Zigbee and saw, that they are connected to a Osram plug, which is offline / not plugged in…
In the same room, as the window (and temp.) sensors are installed I have an other Osram plug (Steckdose 1).
is it possible to “remap” the Aquara sensors to the Steckdose 1 plug to check if then the status change work more reliable?
