ZigBee Push Button Smart Dimmer (Sunricher sr-zg2835pac-au) Firmware Upgrade
I would like to update the firmware on the below mentioned dimmer to be able to turn off the inbuilt blue LED.
I am being told by the seller that:
The blue LED light on the device can only be disabled by updating the firmware. This process must be done using the Sunricher app in combination with the Azoula Zigbee Hub.
I have the Sunricher App but not the Azoula Hub, I use a Sonoff Zigbee 3.0 USB Dongle Plus V2 with my HA Green.
Is there a way to use the Sunricher App with my Sonoff Zigbee Dongle instead of having to buy an Azoula HUB?
Cheers in advance
Markee
did you find any solution to this? I too would like to update my firmware!
No not as yet.
Currently trying to get Z2MQTT up and running to try firmware upgrade via that but having trouble getting the add on to run.
