Zigbee radiator valve (TRV) on external power supply
Most of the available sensors as well as radiator valves work on batteries. This is something I like to avoid, there is always something not working because one of the many batteries requires replacement.
Now about the radiator valves, I have several radiators which are placed behind a ‘panel’ or at a location where it is not easy to replace a battery.
A wall outlet near a radiator is never a problem, so I was planning to us a USB power supply and a 3V step down converter to power the radiator valve.
I initially bough a Tuya, however it turns out, that after a power outage, the button must be pressed twice (calibration ?) before it starts working. This makes the external power supply rather useless.
Another option might be a Sonoff TRVZB. I do not want to buy this as well; it might have the same ‘feature’. Anynone here who has and knows the behaviour after
the batteries are replaced. Does it require button presses as well ?
Anyone else who did (or wants something similar) with a TRV ?
I was not planning to use the valve for autonomous temperature control. Like to have the temperature reading and be able to open or close it.
Some other options I have in mind:
  1. Leave rechargable batteries in and trickle charge with a current source and a few mA. This is safe for the batteries and would keep them charged.
  2. Use a mains powered thermal radiator valve and something to control it (e.g. wall socket)
Any other ideas ? or sugegstions for other valve. Preferably Zigbee, Tasmota would be fine as well.
The Sonoff TRVZB requires a single click after losing power to go from In to Ad, it then comes online, but it always needs that single click, othervise i’d install a “fake battery” that provided correct voltage via a battery-shaped placeholder.
If you are otherwise happy with your setup, you could add UPS module to it. They have commonly USB input, 18650 battery holder and 5V output. ~$2 in AE.
Some models have 3V output option, but for lower current…
I had Hive from a previous house, so when I moved and setup the CH I continued to use Hive including 5 new TRVs. but I did not want to worry about batteries.
I opted to get theses Aieve AA Battery Eliminator, Replace 2 AA Batteries Power Supply Adapter for LED Fairy Light, Thermostat, Table Lamp, Motion Sensor Trash Can, Clocks, Wireless Electronics: Amazon.co.uk: Electronics & Photo
They have been working great. The Hive TRVs do not need any interaction when coming back online. They do however lose the state of the child lock, but that’s a minor issue that can be fixed in the app (if needed).
However you are then locked into Hive. I am looking at migrating over to Hive2MQTT Local HA. Which will allow me to use the Hive TRVs without the cloud.
If I were to start over I’d not go with Hive, before this post at least, Hive do work seamlessly after a power cut.
Since you are using external power anyways then I would suggest a thermal actuator.
They are cheaper than TRVs and don’t have any buttons or other “smart” things that can be an issue.
Thermal actuator + smart plug + temperature sensor is generally cheaper than a TRV but give you a better temperature reading and (generally) a quieter experience.
