Hey Guys,
I just got a (pretty expensive - 68€) rotary knob today.
My plan was to use if for controlling Music assistant as a remote. It has four buttons and a rotary dial. Would be very good for “play, pause, forward, backward”.
The feel is awesome - the dial is buttery-smooth…but:
I just has no function. In ZHA I have found it, but it does not have any entities or does report any data back.
I have no model number (which I found to be a general issue with Zigbee with ZHA).
Has anyone ever seen this device and has any idea how to get it to work?
@Jcarlier unfortunately this know is completely different.
I first also thought about buying it, but the one I have is nicer (if working) due to the additional buttons that I planned to use for pause, play forward etc.
Sure I searched that - which will yield a random assortment of Zigbee switches of any kind.
None of them is close or similar to the one I have.
That was the very first thing I tried.
When clicking on automations - what to chose - if something has no status and no entities and the entities also have no sub-properties, there is just nothing to automate.
I guess there is more or less no way to get it to work.
I even shortly changed my Zigbee-Integration to Zigbee2Mqtt and this is the result:
warning 2025-03-10 18:38:58z2m: Device '0xd87a3bfffed3b391' with Zigbee model 'TS0601' and manufacturer name '_TZE200_xvk16nu8' is NOT supported, please follow https://www.zigbee2mqtt.io/advanced/support-new-devices/01_support_new_devices.html
info 2025-03-10 18:38:58z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xd87a3bfffed3b391","ieee_address":"0xd87a3bfffed3b391","status":"successful","supported":false},"type":"device_interview"}'
Well - I guess the symbols are the same everywhere. But my HA is in German - but not my posts.
I found that the device has a Tuya ZS3L inside. So I guess I’ll give using a Tuya Gateway one final try then it will be sent back to PRC.
I have a similar device and experience to yours, different devices, but seemingly similar.
Have you tried using a Tuya gateway? This device has several modes that only activate after being bound? If so, then it’s similar to my device.
I haven’t been able to create a converter for this device because it seems to require a “magic code” or something. Perhaps it could be cracked/retrieved with a Zigbee sniffer, but even then, there’s no guarantee it will succeed.
