Zigbee sensors not working
I believe since 0.87 upgrade to all the way to current 0.94.3, my zigbee sensor status had been stopped working. They don’t report proper status on HA if I manually turn/off them. It remembers the correct status only if I control them through HA. How do I fix this issue?
Anyone else having same issues?
What sensors are you using and how are they connected to HA?
What is your mqtt configuration?
Have you tried reverting to an older HA version and see if that works?
I’m using Xiaomi zigbee devices with one of those zigbee USB transceiver sticks and everything is working OK on 0.94.3
