Zigbee Smoke Detector Comparison — Full Article, June 2026
Hello everyone,
After months of testing, comparing, and checking everything carefully, I’m sharing my full comparison of the 10 Zigbee smoke detectors currently on the market.
I put them all through a thorough test...
To save you from reading everything, here is my final ranking:
  • In the simple category (very simple) and low-cost, the winner is:
    Nous E8
  • In the full-featured category (my preference), the winning pair is:
    Frient HESZB-120 for the garage or kitchen, and Heiman HS1SA-E-PLUS for the other rooms.
Note that the Heiman HS1SA-E-PLUS is a brand-new version (which replaces the Heiman HS1SA-E); it is outstanding, and I’ll let you discover it for yourself.
https://www.sigalou-domotique.fr/en/comparatif-detecteurs-de-fumee
Please use this topic to critique my comparison — with pleasure. I can correct mistakes; it was a lot of work. Every product tested in depth has its own article detailing its features and the Home Assistant sensors it exposes.
Share your opinion, your experience, and which one do you have? Thoughts?
Hey, thank you very much for this overview. I’m in need of replacing some alarms and this spared me a bunch of time in my research.
The Frient was on my list already, now adding Heiman as they are also on the ”Works with Home Assistant list” Heiman joins Works with Home Assistant - Home Assistant
