Has anyone got a smoke detector working via zigbee2mqtt?
I have a zigbee version of something that looks like this
But I cannot get the options if adding it directly to home assistant so I’m stuck with the original tuya Zigbee hub
It’s my only device left on the tuya Zigbee hub so if I can get rid of these I can throw away tuya Zigbee hub
tom_l
May 2, 2025, 3:31am
2
It is listed as supported 006 and it always shows null.
Actually I tried again it seems the smoke works after you actually started maknig an alarm
OK yes, It was showing as unknown before because somehow it does not read the state but if you make some smoke and it does the alarm then it will show the clear state after that
Thanks for the help.
