ZIgbee soil humidity sensor
Could anyone suggest a reliable zigbee soil humidity sensor? I have this one but its keeps dropping offline.
thanks
Hello Commander007,
Add a smart plug as close as you can to the device to act as a router. Most likely mesh problems. thirdreality usually have pretty good radios.
The Home Assistant Cookbook - Index.
Ok thanks. Oddly its connected to the main hub even though there are routing switches and outlets closer. I’ll try and persuade it to change its connection path.
There are a lot of reviews on Amazon saying that particular device has a poor signal.
I use the Xiaomi mi flora and they work fine.
But they are Bluetooth not Zigbee.
