Zigbee switch turns on at Home Assistant startup
I have a zigbee switch that commands two lights.
When Home Assistant starts, the lights turn on by themselves and I don't know why.
The automations that command these lights don't mention any startup behavior, so this shouldn't happen.
In the Z2M "exposes" tab, there's only a settings for "power on behavior" but it is set to OFF.
I really don't understand. Any suggestions?
Post your automation.
This is in effect when the device physically looses power, what it should to when the power comes back on.
It's actually three automations:
alias: Luci Scale & Cantina 1/3
description: I sensori fanno partire il timer
triggers:
  - trigger: state
    entity_id:
      - binary_sensor.movimento_cantina
    to:
      - "on"
  - trigger: state
    entity_id:
      - binary_sensor.porte_downstairs
    enabled: false
    to:
      - "on"
  - trigger: state
    entity_id:
      - binary_sensor.porta_cantina_contact
    to:
      - "on"
  - trigger: state
    entity_id:
      - binary_sensor.porta_scale_contact
    to:
      - "on"
conditions: []
actions:
  - data:
      duration: "00:02:00"
      entity_id: timer.tempolucescale
    action: timer.start
mode: single
alias: Luci Scale & Cantina 2/3
description: Quando parte il timer, accendi luce
triggers:
  - entity_id:
      - timer.tempolucescale
    to: active
    trigger: state
conditions: []
actions:
  - action: light.turn_on
    metadata: {}
      entity_id: light.luci_scale_cantina
    data: {}
mode: single
alias: Luci Scale & Cantina 3/3
description: Scaduto il timer, spegni la luce se non c'è nessuno presente
triggers:
  - entity_id:
    to: idle
    trigger: state
conditions: []
actions:
  - choose:
      - conditions:
          - condition: state
            entity_id: binary_sensor.presenza_cantina
            state:
              - "on"
        sequence:
          - action: timer.start
            metadata: {}
            data: {}
      - conditions:
          - condition: state
            state:
              - "off"
        sequence:
          - action: light.turn_off
            metadata: {}
            data: {}
    enabled: false
  - if:
      - condition: state
        entity_id: binary_sensor.attivita_cantina
        state:
          - "on"
    then:
        metadata: {}
        data: {}
    else:
        metadata: {}
          entity_id:
            - light.luci_scale_cantina
        data: {}
mode: single
I know, I only mentioned it for "completeness" :slight_smile:
add
not_from:
- unavailable
to all your triggers matching the indentation of to:.
e.g.
  - trigger: state
    entity_id:
    to:
      - "on"
    not_from:
      - unavailable
EDIT: Actually, you can simplify your automation by combining the triggers.
triggers:
  - trigger: state
    entity_id:
    to:
      - "on"
    not_from:
      - unavailable
conditions: []
actions:
  - data:
    action: timer.start
mode: single
Thanks a lot, I'm gonna try and see if it solves.
(BTW: I created the automations using the GUI, that's probably why they are not very "refined")
EDIT: it worked!! Thank you so much!!
