Zigbee Thermostat with power monitor
I was surprised that I cant find thermostats for electric floor heating that uses zigbee and has power monitoring. Preferably a cheep one from aliexpress. Do i have to have bothe thermostat and tuas relys with power monitoring? Great if it is also used as a zigbee router.
This one looks great:
https://www.aliexpress.com/item/1005007171381304.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.2.1bc78GBv8GBvHf&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40196.439370.0&scm_id=1007.40196.439370.0&scm-url=1007.40196.439370.0&pvid=effcf790-620e-4aae-b7c6-acca1ba4322b&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40196.439370.0,pvid:effcf790-620e-4aae-b7c6-acca1ba4322b,tpp_buckets:668%232846%238114%231999&pdp_ext_f={"order"%3A"2720"%2C"eval"%3A"1"%2C"orig_sl_item_id"%3A"1005007171381304"%2C"orig_item_id"%3A"1005005230261106"%2C"sceneId"%3A"30050"%2C"fromPage"%3A"recommend"}&pdp_npi=6%40dis!SEK!530.23!228.93!!!384.45!165.99!%40211b612517641822668791293e3deb!12000039693342452!rec!SE!6224428323!X!1!0!n_tag%3A-29919%3Bd%3A93efa2ce%3Bm03_new_user%3A-29895%3BpisId%3A5000000193994497&utparam-url=scene%3ApcDetailTopMoreOtherSeller|query_from%3A|x_object_id%3A1005007171381304|_p_origin_prod%3A1005005230261106
This one also looks great:
https://www.aliexpress.com/item/1005007628099393.html?spm=a2g0o.productlist.main.6.88db27c0kbyYS8&aem_p4p_detail=202511261058308108056456260600001517485&algo_pvid=b41500e0-ff7e-4339-8969-f3eb07c5c627&algo_exp_id=b41500e0-ff7e-4339-8969-f3eb07c5c627-5&pdp_ext_f={"order"%3A"591"%2C"eval"%3A"1"%2C"fromPage"%3A"search"}&pdp_npi=6%40dis!SEK!619.69!224.39!!!449.31!162.69!%40211b61bb17641835104926132efe9d!12000041562068603!sea!SE!6224428323!X!1!0!n_tag%3A-29919%3Bd%3A93efa2ce%3Bm03_new_user%3A-29895%3BpisId%3A5000000193837172&curPageLogUid=MSrwFzNRtC4D&utparam-url=scene%3Asearch|query_from%3A|x_object_id%3A1005007628099393|_p_origin_prod%3A&search_p4p_id=202511261058308108056456260600001517485_2
But as far as i can see they do not have power monitoring.
Does anyone have any tips?
One tip would be to state where in the world you are located, as selections vary.
Sweden, but i think aliexpress and amazon ships all over the world? As long as it is 230v ac i guess?
I am new to this so i am not sure :slight_smile:
There’s plenty of options in Sweden, here for example Smarta termostater för energieffektiv och bekväm uppvärmning | Elbutik
I use Namron here, they give you power readings.
