We are working on integrating a Zigbee ultrasonic heat energy meter into Home Assistant for HVAC and hydronic heating/cooling systems.
This device is not a traditional water meter, but a thermal energy meter (heat/cooling energy consumption in kWh or MJ equivalent) based on ultrasonic flow measurement and temperature differential.
It is commonly used in:
- Floor heating systems
- District heating
- HVAC chilled water loops
- Fan coil systems
- Building energy monitoring
- Thermal energy billing
Open-source Home Assistant integration
We currently support both major Zigbee ecosystems:
Zigbee2MQTT support (MQTT-based integration)
Implementation:
This converter exposes:
- Flow rate (m³/h)
- Supply water temperature
- Return water temperature
- Heating / cooling energy (kWh / MJ equivalent)
- MQTT entities for Home Assistant
This makes it compatible with:
- Home Assistant Energy Dashboard (via MQTT sensors)
- Utility Meter / long-term energy tracking
- Custom automation based on thermal load
ZHA native support (quirk-based integration)
Implementation:
This quirk enables:
- Direct Zigbee integration via ZHA (zigpy)
- Native sensor exposure (flow / temperature / energy)
- No MQTT required
- Device-specific cluster mapping for correct reporting
Device technical overview
Based on ultrasonic heat metering principles:
- Ultrasonic flow measurement (no moving parts)
- Thermal energy calculation using flow and temperature differential
- Designed for heating and cooling system applications
- Intended for continuous HVAC monitoring environments
Why ultrasonic heat meters are interesting for Home Assistant
Compared to traditional mechanical flow meters:
- No impeller-based mechanical wear
- Reduced risk of blockage from debris
- Potentially more stable over long-term operation
- Suitable for thermal energy monitoring and billing applications
- Direct measurement of thermal energy instead of estimated consumption
Potential Home Assistant use cases
Possible integrations include:
- Potential Home Assistant Energy Dashboard integration
- Floor heating monitoring
- HVAC efficiency tracking
- Boiler / chiller loop visualization
Community feedback welcome
We would appreciate feedback from the Home Assistant community regarding:
- Best practice for integrating heat energy data into HA dashboards
- ZHA vs Zigbee2MQTT preference for energy metering devices
- Long-term reliability of ultrasonic heat meter reporting
- Existing EN1434-style heat meter integrations in Home Assistant
References
Product page:
Final note
This type of device sits somewhere between traditional HVAC instrumentation and smart home energy monitoring. We are interested in exploring how thermal energy metering can be integrated more effectively into the Home Assistant ecosystem.
