Zigbee: usb-stick was renamed
Hi there.
Since a year, I use HA in a proxmox vm. For zigbee-devices I have Conbee 3 stick.
Everything worked fine.
After a kernel-update of the proxmox host, the conbee 3 stick was renamed as “Future Technology Devices International”.
The consequence is, that HA does not find the path of the stick:
Failed setup, will retry: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-dresden_elektronik_ConBee_III_DE03187831-if00-port0'
The stick is now named as " /dev/serial/by-id/usb-FTDI_FT232EX-if00-port0" in /dev.
In HA core-lo I found this:
Error with zha describe event for zha_event
  File "/usr/src/homeassistant/homeassistant/components/logbook/processor.py", line 259, in _humanify
    data = describe_event(event_cache_get(row))
  File "/usr/src/homeassistant/homeassistant/components/zha/logbook.py", line 44, in async_describe_zha_event
    zha_device = async_get_zha_device_proxy(
        hass, event.data[ATTR_DEVICE_ID]
    ).device
  File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1077, in async_get_zha_device_proxy
    zha_gateway_proxy = get_zha_gateway_proxy(hass)
  File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1056, in get_zha_gateway_proxy
    raise ValueError("No gateway object exists")
ValueError: No gateway object exists
What can I do to bring up the zha-integration again?
I already disconnected the stick and assigned it with new name to usb-port in HA.
Hello ulihueck,
Change the name in ZHA to the right one. I don’t know specifically, but you may have to remove it and reset it up, don’t know.
How can I change the name in zha to the right one?
