Zigbee Wall Module genLevelCtrl for normal push button
Hi all
I’m looking for a zigbee in wall module which exposes genLevelCtrl / genOnOff and still has a connection for a normal push button. The reason is, that I’d like to use my existing push buttons to control my hue lights via Z2M with direct binding for it to be controlled even when HA is not available. I’d like something which doesn’t use batteries.
There is this wall switch called zigfred which provides this but I’d like the feel of my current feller push buttons better.
Any ideas?
Many devices are only available in certain countries, so I would include my location to the post.
Location is Switzerland. Functionality-wise I was thinking about a hue dimmer switch in form of a shelly wall module which takes a single push button (short press on/off, long press dim) and normal L/N wiring to power the module itself.
There’s a tuya list of relays/switches here where you can flash custom firmware via ota to enable those features
Thanks a lot for this hint. I’ll have a look at it.
