Hi all,
Somewhat of a newbie to HA, and definitely a newbie to working with the Zigbee2MQTT. It seems from my reading that Zigbee2mqtt is more compatible with a wider range of devices (correct me if I a wrong!) so I decided to “upgrade” from current Zigbee coordinator (a Sonoff Zigbee USB Dongle Plus-ZBDongle-E) [connected via USB] to a SLZB-06M. I was looking for a networked based one so that it is not dependent on the state of my PC which though up 24/7, occasionally will need to be rebooted. My SLZB is connected to my hub and I am able to access the GUI by IP address. I was setting up my SLB-06 via these instructions:
https://thebloody.cloud/posts/Installing-Zigbee2MQTT/
It seemed to be going along well, but when I try to actually access the Zigbee2MQTT I get a 502 Bad gateway error (see screenshot below)
I took a look at the Zigbee2MQTT logs and I do see that it seems to “reset” every so often. I guess I was wondering a few things. I know I currently have my other zigbee coordinator (the Sonoff) in production. I did setup the SLZB-06M to be a Zigbee router if that helps any and to avoid any conflicts with the Sonoff. Could that be part of the issue? I have the following from the logs of Zigbee2MQTT addon:
[2025-05-25 21:23:23] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:26] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:26] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:29] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:29] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:31] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:31] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:34] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:34] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:36] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-05-25 21:23:36] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-05-25 21:23:36] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-25 21:23:36] e[31merrore[39m: z2m: Exiting...
[2025-05-25 21:23:36] e[31merrore[39m: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24)
at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at Controller.start (/app/lib/controller.ts:104:13)
at start (/app/index.js:149:5)
[21:23:37] INFO: e[32mPreparing to start...e[0m
[21:23:37] INFO: e[32mSocat not enablede[0m
[21:23:37] INFO: e[32mStarting Zigbee2MQTT...e[0m
Starting Zigbee2MQTT without watchdog.
[2025-05-25 21:23:38] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-05-25 21:23:38] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-25 21:23:38] e[32minfoe[39m: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-25 21:23:38] e[32minfoe[39m: zh:ember: Using default stack config.
[2025-05-25 21:23:38] e[32minfoe[39m: zh:ember: ======== Ember Adapter Starting ========
[2025-05-25 21:23:38] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP starting ========
[2025-05-25 21:23:38] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:38] e[32minfoe[39m: zh:ember:uart:ash: Socket ready
[2025-05-25 21:23:38] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:41] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:41] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:43] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:43] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:46] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:46] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:48] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:48] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:51] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-05-25 21:23:51] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-05-25 21:23:51] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-25 21:23:51] e[31merrore[39m: z2m: Exiting...
[2025-05-25 21:23:51] e[31merrore[39m: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
[21:23:51] INFO: e[32mPreparing to start...e[0m
[21:23:51] INFO: e[32mSocat not enablede[0m
[21:23:51] INFO: e[32mStarting Zigbee2MQTT...e[0m
[2025-05-25 21:23:52] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-05-25 21:23:52] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-25 21:23:52] e[32minfoe[39m: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-25 21:23:52] e[32minfoe[39m: zh:ember: Using default stack config.
[2025-05-25 21:23:52] e[32minfoe[39m: zh:ember: ======== Ember Adapter Starting ========
[2025-05-25 21:23:52] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP starting ========
[2025-05-25 21:23:52] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:52] e[32minfoe[39m: zh:ember:uart:ash: Socket ready
[2025-05-25 21:23:52] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:55] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:55] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:23:58] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:23:58] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:00] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:00] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:03] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:03] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:05] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-05-25 21:24:05] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-05-25 21:24:05] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-25 21:24:05] e[31merrore[39m: z2m: Exiting...
[2025-05-25 21:24:05] e[31merrore[39m: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
[21:24:05] INFO: e[32mPreparing to start...e[0m
[21:24:06] INFO: e[32mSocat not enablede[0m
[21:24:06] INFO: e[32mStarting Zigbee2MQTT...e[0m
[2025-05-25 21:24:06] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-05-25 21:24:07] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-25 21:24:07] e[32minfoe[39m: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-25 21:24:07] e[32minfoe[39m: zh:ember: Using default stack config.
[2025-05-25 21:24:07] e[32minfoe[39m: zh:ember: ======== Ember Adapter Starting ========
[2025-05-25 21:24:07] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP starting ========
[2025-05-25 21:24:07] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:07] e[32minfoe[39m: zh:ember:uart:ash: Socket ready
[2025-05-25 21:24:07] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:09] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:09] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:12] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:12] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:14] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:14] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:17] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:17] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:19] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-05-25 21:24:19] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-05-25 21:24:19] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-25 21:24:19] e[31merrore[39m: z2m: Exiting...
[2025-05-25 21:24:19] e[31merrore[39m: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
[21:24:20] INFO: e[32mPreparing to start...e[0m
[21:24:20] INFO: e[32mSocat not enablede[0m
[21:24:20] INFO: e[32mStarting Zigbee2MQTT...e[0m
[2025-05-25 21:24:21] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-05-25 21:24:21] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-25 21:24:21] e[32minfoe[39m: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-25 21:24:21] e[32minfoe[39m: zh:ember: Using default stack config.
[2025-05-25 21:24:21] e[32minfoe[39m: zh:ember: ======== Ember Adapter Starting ========
[2025-05-25 21:24:21] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP starting ========
[2025-05-25 21:24:21] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:21] e[32minfoe[39m: zh:ember:uart:ash: Socket ready
[2025-05-25 21:24:21] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:23] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:23] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:26] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:26] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:28] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:28] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:31] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 21:24:31] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 21:24:34] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-05-25 21:24:34] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-05-25 21:24:34] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-25 21:24:34] e[31merrore[39m: z2m: Exiting...
[2025-05-25 21:24:34] e[31merrore[39m: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
[22:17:43] INFO: e[32mPreparing to start...e[0m
[22:17:43] INFO: e[32mSocat not enablede[0m
[22:17:43] INFO: e[32mStarting Zigbee2MQTT...e[0m
[2025-05-25 22:17:44] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-05-25 22:17:44] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-25 22:17:44] e[32minfoe[39m: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-25 22:17:44] e[32minfoe[39m: zh:ember: Using default stack config.
[2025-05-25 22:17:44] e[32minfoe[39m: zh:ember: ======== Ember Adapter Starting ========
[2025-05-25 22:17:44] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP starting ========
[2025-05-25 22:17:44] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:17:44] e[32minfoe[39m: zh:ember:uart:ash: Socket ready
[2025-05-25 22:17:44] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:17:47] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:17:47] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:17:49] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:17:49] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:17:52] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:17:52] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:17:54] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:17:54] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:17:57] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-05-25 22:17:57] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-05-25 22:17:57] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-25 22:17:57] e[31merrore[39m: z2m: Exiting...
[2025-05-25 22:17:57] e[31merrore[39m: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
[22:17:57] INFO: e[32mPreparing to start...e[0m
[22:17:57] INFO: e[32mSocat not enablede[0m
[22:17:58] INFO: e[32mStarting Zigbee2MQTT...e[0m
[2025-05-25 22:17:58] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-05-25 22:17:58] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-25 22:17:58] e[32minfoe[39m: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-25 22:17:59] e[32minfoe[39m: zh:ember: Using default stack config.
[2025-05-25 22:17:59] e[32minfoe[39m: zh:ember: ======== Ember Adapter Starting ========
[2025-05-25 22:17:59] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP starting ========
[2025-05-25 22:17:59] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:17:59] e[32minfoe[39m: zh:ember:uart:ash: Socket ready
[2025-05-25 22:17:59] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:01] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:01] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:04] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:04] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:06] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:06] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:09] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:09] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:11] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-05-25 22:18:11] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-05-25 22:18:11] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-25 22:18:11] e[31merrore[39m: z2m: Exiting...
[2025-05-25 22:18:11] e[31merrore[39m: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
[22:18:12] INFO: e[32mPreparing to start...e[0m
[22:18:12] INFO: e[32mSocat not enablede[0m
[22:18:12] INFO: e[32mStarting Zigbee2MQTT...e[0m
[2025-05-25 22:18:13] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-05-25 22:18:13] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-25 22:18:13] e[32minfoe[39m: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-25 22:18:13] e[32minfoe[39m: zh:ember: Using default stack config.
[2025-05-25 22:18:13] e[32minfoe[39m: zh:ember: ======== Ember Adapter Starting ========
[2025-05-25 22:18:13] e[32minfoe[39m: zh:ember:ezsp: ======== EZSP starting ========
[2025-05-25 22:18:13] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:13] e[32minfoe[39m: zh:ember:uart:ash: Socket ready
[2025-05-25 22:18:13] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:16] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:16] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:18] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:18] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:21] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:21] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:23] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-05-25 22:18:23] e[32minfoe[39m: zh:ember:uart:ash: ======== ASH starting ========
[2025-05-25 22:18:26] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-05-25 22:18:26] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-05-25 22:18:26] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-05-25 22:18:26] e[31merrore[39m: z2m: Exiting...
[2025-05-25 22:18:26] e[31merrore[39m: z2m: Error: Failed to start EZSP
My Zigbee2MQTT Config looks like this:
I was reading on the forums about disabling my current Zigbee coordinator (flush all the settings of the previous dongle) but I wanted to get some other thoughts before I take that path. Is it possible to have a zigbee coordinator and router as part of the HA setup? I’m actually leaning towards making this my sole zigbee coordinator if that works better
