Anyone one willing to shed some light on automations? I’m trying to setup my new setup and I can’t get it to run. Specifically using Zigbee2MQTT. I found very specific examples matching my issue but the accepted solutions don’t seem to work.
What I am trying to do: I have a Xiaomi WXKG11LM button switch connected to HA via Zigbee2MQTT and I want to control a couple TP-Link HS100s with it.
I can see the messages appearing through zigbee (copied below) and the devices in HA. The automation isn’t triggering though. I’m sure it is something with my auotmations.yaml but I can’t tell what is wrong. Any thoughts?
Zigbee2MQTT Output:
zigbee2mqtt:info 2020-01-12 12:48:38: MQTT publish: topic 'zigbee2mqtt/0x00158d0002904e05', payload '{"battery":100,"voltage":3055,"linkquality":70,"click":"single"}'
zigbee2mqtt:info 2020-01-12 12:48:38: MQTT publish: topic 'zigbee2mqtt/0x00158d0002904e05', payload '{"battery":100,"voltage":3055,"linkquality":70,"click":""}'
zigbee2mqtt:info 2020-01-12 12:48:42: MQTT publish: topic 'zigbee2mqtt/0x00158d0002904e05', payload '{"battery":100,"voltage":3055,"linkquality":55,"click":"double"}'
zigbee2mqtt:info 2020-01-12 12:48:42: MQTT publish: topic 'zigbee2mqtt/0x00158d0002904e05', payload '{"battery":100,"voltage":3055,"linkquality":55,"click":""}'
automations.yaml: I have copied the entire filre. All the different ones I have tried are commented out-
alias: Turn on Bedroom Lights
description: ''
hide_entity: true
platform: state
entity_id: sensor.0x00158d0002904e05_click
to: 'single'
- device_id: 16f5e3730e254c1e9b05bbca817862f6
domain: switch
entity_id: switch.bedroom_floor_lamp
type: turn_on
# - alias: Turn on Lyndseys Lamp
# trigger:
# platform: state
# entity_id: sensor.0x00158d0002904e05_click
# to: 'double'
# action:
# - data:
# entity_id: switch.bedroom_floor_lamp
# type: switch.turn_on
# - id: '1578846412196'
# alias: Turn on Lyndseys Lamp
# trigger:
# - platform: mqtt
# topic: 'zigbee2mqtt/0x00158d0002904e05'
# condition:
# - condition: template
# value_template: '{{ "double" == trigger.payload_json.click }}'
# action:
# - device_id: 16f5e3730e254c1e9b05bbca817862f6
# domain: switch
# type: turn_on
# - id: toggle_my_light
# alias: Turn_on_off_yeelight
# trigger:
# platform: state
# to: 'single'
# action:
# service: switch.toggle
