I’m having problems trying to start the Zigbee2mqtt with the a new dongle I just got is the Sonoff Sigbee Plus-E.
This is the error I got:
[22:07:01] INFO: Preparing to start…
[22:07:01] INFO: Socat not enabled
[22:07:01] INFO: Starting Zigbee2MQTT…
Starting Zigbee2MQTT without watchdog.
[2024-11-30 22:07:09] warning: zh:ezsp: ‘ezsp’ driver is deprecated and will only remain to provide support for older firmware (pre 7.4.x). Migration to ‘ember’ is recommended. If using Zigbee2MQTT see Improved Ember (EZSP) driver (experimental) · Koenkk/zigbee2mqtt · Discussion #21462 · GitHub
[2024-11-30 22:07:12] error: z2m: Error while starting zigbee-herdsman
[2024-11-30 22:07:12] error: z2m: Failed to start zigbee
[2024-11-30 22:07:12] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-11-30 22:07:12] error: z2m: Exiting…
[2024-11-30 22:07:12] error: z2m: Error: This open coordinator backup format not for EZSP adapter
at EZSPAdapterBackup.getStoredBackup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/backup.ts:97:23)
at Driver.needsToBeRestore (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:943:45)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:244:40)
at EZSPAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:152:16)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
