Zigbee2MQTT - Blueprint to control multiple lights with a single light switch (IKEA Rodret, Hue Dimmer Switch)
A simple automation that allows you to control the on/off state and brightness of multiple lights with a single light switch.
Works with ZIgbee2MQTT and tested with IKEA Rodret and Hue Dimmer Switch.
  • Every time you press the ON button the next light will be turned on.
  • The OFF button turns off all lights.
  • It supports the brightness buttons on Hue Dimmer Switch and holding ON/OFF buttons on IKEA Rodret to change the brightness.
:link: Github link
Hi, love this blueprint. would it be possible to alter the yaml to reset rgb bulbs to White & 50% brightness for the initial β€œon” instance?
