I’m not sure how to understand this (marked in bold below:)
" * Breaking changes
- Most Zigbee2MQTT configuration is now done in Zigbee2MQTT directly (either via the UI or by modifying the configuration file, usually
/config/zigbee2mqtt/configuration.yaml
, directly).As Zigbee2MQTT won’t start with an [MQTT server]
You must configure these through the add-on configuration page before you can start Zigbee2MQTT for the first time.
Existing installations should be able to safely remove the Zigbee2MQTT configuration from the add-on configuration as these values should have already been persisted to the configuration file.
Does this mean that after upgrading I caan safely remove the configuration.yaml in /config/zigbee2mqtt/configuration.yaml? I don’t want to mess my almost 200 devices up…
