Zigbee2mqtt: cannot add new devices (after updates), what am i missing?
Ok, so im sitting here after large zigbee2mqtt (and HA) update after about 9 months, and all my devices work as expected but i can no longer add new devices nor can i repair previous devices. Any help is appreciated. Here is the full story:
Zigbee coordinator: SMLight SLZB-06
Couple of days ago:
The system was running perfectly fine, but nothing was updated in about 9 months (SLZB-06, HA, z2m). But i was still able to add new devices to Z2M, all automations and devices were working as well. I had purchased a bunch of new aqara T2 bulbs, and when adding to z2m, it adds successfully but it is an unrecognised device (still works but with some issues) - its because z2m was not updated to have device details for Aqare t2 bulbs. Anyway, i decided to do a FULL update to HA / SLZB-06 / Z2M / etc…
Doing the update:
Update went ok-ish. Z2M did not start up. I hit the pan id issue described here. I followed the instructions, changed the pan id, z2m started, changed the pan id back, z2m started fine but without any devices, but then copied over the database backup file (all in the instructions from the link), and all seems to be fine. Everything worked, automations worked etc. Z2M has nice new interface now.
Now:
I attempted to add an aqara T2 bulb (yes, converted to zigbee mode), permit join (all), put it in pairing mode, nothing. Repeat… nothing. No bulb appears on Z2M devices. [all existing devices through z2m still work fine].
I attempted to remove one of my living room bulbs and re-pair it to test (older aqara T1 bulb), it deletes fine. permit join (all) again, put the bulb into pairing mode, bulb brinks few times, then stops blinking, but nothing on Z2M devices. Repeat… nothing.
So i cannot get zigbee devices to connect to Z2M anymore, wtf is going on? I dont even know where to begin to start debugging this issue. The existing zigbee network works just fine (well, it seems fine atleast), i just cant add anything anymore. I feel like when i put something to pairing mode, it gets paired up to some other zigbee network or something (the aqara T1 bulb stops blinking - i think implies that it connected to another network, correct me if im wrong). I do not have any other zigbee hub, just the one SMLight SLZB-06 configured to use with the ONE instance of HA Z2M.
Any suggestions or insights are very much appreciated.
First thing I would do is copy the backup right before the entire backup to a save place before doing anything!
Yup, thats fair.
Firstly, Its not the end of the world for me to completely re-pair everything (i would be totally fine to reset all the zigbee devices).
Worst case scenario, i do have a full VM backup of the whole HA instance before and after the full update. I can always revert back to this if needed.
Honestly, rather than reverting back, i just want to move forward and sort the issue. I just want some idea to be able to debug the issue and resolve it. Right now, im basically nuking the whole database and going to try start from scratch (i can always revert back to a backup if need be). Im just out of suggestions and things i can do - so im just doing silly things expecting a different outcome.
…well, nuking the devices worked. I deleted the content of zigbee2mqtt/database.db and the device list from zigbee2mqtt/configuration.yaml.
Now i can pair things. i just have to start from scratch. Fun!
…hope this helps someone :slight_smile:
Happy new year!
It sounds like an user rights issue on the database file.
I am having the same exact issue. I have an slzb-06 coordinator too on my z2m. I updated its OS from 3.1.3 to 3.2.0 and the radio firmware from 20230507 to 20240710. I had the panid issue, z2m won’t start, so me too I found the smlight article Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby Error: AREQ - ZDO - stateChangeInd after 60000ms
now z2m starts, I have all my devices, everything works well, HOWEVER … I can’t pair new devices, even old ones, if I unpair them I can’t pair them again.
I looked at the database.db user rights like suggested by @edwin-2023 it’s all good there, I don’t want to nuke my devices and have to start again like your did @syrys … Any help to fix this without having to start from scratch would be really appreciated.
Thanks.
Sorry for late response, unfortunately I nuked and didn’t look back. I was in a position where nuking wasent a big deal as I had just moved house and was going to re do most things anyway. Also since then I have had couple of issues where z2m wouldn’t start (failing to connect to slzb06), the I looked closely at the slzb06 firmware and realised that one of them was on a beta release and not stable release (which was from 2024 or something). I reverted to the last stable release (again from memory it was dated 2024 or something) and all was good again with my smart home.
Hope you found out some solution for your case :slight_smile:
The same issue here.
I have not added new devices for a few months and now noticed that I can’t.
Have not had any issues with regular updates for a year or more.
