According the breaking changes I should add this to configuration.yaml
advanced:
homeassistant_legacy_entity_attributes: false
homeassistant_legacy_triggers: false
legacy_api: false
legacy_availability_payload: false
device_options:
legacy: false
However this is my configuratuion.yml
homeassistant:
enabled: true
legacy_action_sensor: false
experimental_event_entities: false
mqtt:
server: mqtt://core-mosquitto:1883
user: ********
password: *******
version: 5
serial:
port: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220810134749-if00
adapter: ezsp
frontend:
enabled: true
port: 8099
advanced:
log_syslog:
app_name: Zigbee2MQTT
eol: /n
host: localhost
localhost: localhost
path: /dev/log
pid: process.pid
port: 123
protocol: tcp4
type: '5424'
transmit_power: 10
channel: 15
log_level: info
device_options: {}
devices:
I’ve snipped the devices and hidden user/password from above
I’ve updated to v2 (latest), and my zigbee is working fine, apart from illuminance sensor renamed, I’ve made no other changes.
Should I leave the config alone or make the changes regardless?
