I recently added a couple of new devices to the network, and one of them, a SONOFF ZBMINIR2 switch, will periodically have an error when using the physical switch connected to it. So, I found that it can be fixed with a firmware update. But I go and try checking for OTA updates, and either the whole Zigbee2MQTT system crashes and restarts, or the adapter does, I cannot know the difference.
The case is that I lose control of all my zigbee devices for some seconds and I cannot access the Zigbee2MQTT frontend for a moment, then, it comes back. I’ve tried checking for updates of other devices because I thought the new switch could be the problem, but it still does the same for the other devices. I also have realised that if I look at the firmware attribute in HA, for all the devices that support OTA updates, both “installed_version” and “latest_version” have -1 values.
Could anyone help me figure out what I can do to fix my OTA updates?
Thanks!!
What did you expect to happen?
Check for updates succesfully and show if there’s any new version
How to reproduce it (minimal and precise)
- OTA tab
- Click “Check for updates” in any device
Zigbee2MQTT version
2.1.1
Adapter firmware version
8.0.2 [GA]
Adapter
ZB-GW04 (v1.2)
Setup
docker container in RPi3b+
Debug log
No log is created when it happens, because it instantly crashes after “z2m: Checking if update available for …”
