Zigbee2MQTT doesn't show state of light
I have configured Zigbee2MQTT and started with 1 hue bulb to test.
|Model|8718696695203| Philips Hue white ambiance E14|
Now I can turn on the light the usual way, but the switch immediately goes backt to the off position.
state keeps telling it is off while the light is actually on.
After that a can not turn of the light with this switch other than quickly press twice…
Anyone an idea on how I can make this work?
Have you configured the light manually or used Zigbee2MQTT discovery feature?
I used the discover feature.
Hmm … I use this type of bulb too with Zigbee2MQTT and it works perfectly. I use a dedicated Zigbee2MQTT instance, not the HA add-on.
If the slider returns to off position immediately, the command cannot be send or the outcome is not properly reflected. Since you see the light turn on/off - it’s the later.
Any messages in the logs of HA, MQTT oder Zigbee2MQTT? Any customizations for that device in Zigbee2MQTT’s devices list/file?
This is what i am getting in the log.
Error Publish 'set' 'state' to 'Sfeerlicht boven' failed: 'Error: Command 0x0017880103b819a2/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received)'
Debug Error: Command 0x0017880103b819a2/11 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (no response received) at DeconzAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:606:23) at Generator.throw (<anonymous>) at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/deconz/adapter/deconzAdapter.js:25:65)
Info MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Sfeerlicht boven' failed: 'Error: Command 0x0017880103b819a2/11 genOnOff.off({}, {\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null}) failed (no response received)'","meta":{"friendly_name":"Sfeerlicht boven"},"type":"zigbee_publish_error"}'
What do you mean by dedicated zigbee2mqtt
Sorry, but the error message is not something I’ve seen so far. It looks like HA fails to publish the state-changing message or at least it “thinks” that it could not publish the message, but obviously that’s not the case.
Sorry, cannot help more.
A Zigbee2MQTT installation not embedded in HA (as an add-on), but running standalone. I don’t use Home Assistant OS or Supervised.
No problem thanks for trying.
For now i connected it bach to hue.
